What is the explanation for Miller furnace flashing two times and will not run. Have replaced ignitor coil already. Fan runs though. Any suggestions besides calling technician (already in process)?
  • 53 Answers
Two flashes usually mans lack of intake air
Posted on Dec 23, 2014
Testimonial: "After calling technician, we had to replace heater motor and fan wheel."
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Posted on Dec 05, 2007
SOURCE: goodman gmp075-3 led blinks 5 times
I Also have the same and other problems with my furnace model # GDS80703AXBB. First the LED kept blinking 4 times and I too jumped the primary limit, that didn't kelp. After several attemps I moved the wires going to the circut board and everything starting working again. After a week It stopped working again, so I pulled the plug out of the circut board checked all wires for for a bad connection plugged it back in. Now the LED blinks 6 times again I move the wires. Then the LED blinks 3 times. Then the transformer burns out. I have burned out 2 transformers and I have ordered a new circut board.
Posted on Nov 15, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
Posted on Dec 04, 2008
  • 12 Answers
SOURCE: Furnace cuts out because of "low air flow", then starts again
try the furnace without the filter. if it stays running then find out what filter came with the furnace. if you have the owners manual. look for the simple things first. blockage, is the motor and fan runnin properly.. good luck
Posted on Apr 09, 2009
heatman101
  • 43501 Answers
SOURCE: Burner ignites and goes out (Goodman Gas-fired furnace)
The problem you have is water in the exhaust pipe.
Check to see if the pipe has sagged anywhere or if there is a trap in the line.
If you hear gurgling then it is definetly water....
Some times can be hard to find, even a pipe 1/4 full will cause problems. They are very sensitive to flue problems.
Make sure that the flue pipe either runs back to the furnace or out to the outside, a continuos slope either way witha high spot in the middle.
Also check the bottom drain of the blower if it has one, have had them plug and trap water also..
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
I have an 11 year old natural gas forced air furnace--a Goodman GMPN100-4 Rev B, which is 100K BTU and 92% efficient which was working fine at the end of last winter. I went to turn it on for the first...
You are correct. If the inducer motor is warm, but not running, it has seized up. If you replace this yourself, I also suggest that when you replace the inducer fan, check to make sure the secondary heat exchanger isn't clogged, or the condensate drain(s). If you have an HVAC contractor replace it, he should do this for you. It shouldn't run more than $350, to have it replaced and he can check for clogs (The price I'm quoting is for standard hours).
You can check this yourself by running the inducer fan without it being attached to the furnace, then attaching it to the furnace. If you notice a significant reduction in airflow, then you have a clogged secondary heat exchanger. I've run across this situation before on this particular model. The owner recenly replaced the inducer motor, but couldn't figure out why he was still having problems. I suspect the clogged heat exchanger contributed to the inducer motor to failing previously, and feel It would definitely be worth checking while you have the fan removed to help eliminate any future problems that could result from this, including heat exchanger failure. The manufacturer of this unit actually recommends you clean the secondary heat exchanger every year, but this is overkill if your furnace was installed and set up properly. I'd recommend doing it every 10 years and you're at that mark now. Instructions on how to do this are in the manual for this unit if you have it. Otherwise, e-mail me at wheels38_97@yahoo.com and I can send you a copy.
Finally, check the limit and flame roll out switches after replacing, as they could have tripped when the motor failed.
Oct 22, 2010 | Heating & Cooling
My Miller furnace occasionally stops in mid
If the flame looks good prior to the room air blower starting but becomes unstable when the blower starts, you have a crack or hole in the heat exchanger. I strongly suggest your technician do a test on it to see.
Dec 04, 2009 | Heating & Cooling
Miller propane furnace .red light flashes 5 times
Look on the wiring diagram for an error code chart. It will give you a starting piont.
Dec 01, 2009 | Polaroid Heating & Cooling
Miller gas furnace not firing but the fan turns on
The Miller furnaces sometimes will do that. Does this have surface ignitor that glows. Kill power to furnace for few seconds and turn it back on. See if it will go thri the cycle and see if coil glows. If not chances are coil is bad. Need to call service tech for free estimate. Rus
Nov 06, 2009 | Heating & Cooling
I have air coming from the vents but no heat. The furnace is 23 years old and I've never replaced anything in the unit. Best guess? GE Intertherm. thanks
If the thermostat is set on Fan and not Auto the fan will continue to run. If the fan control is bad or is set at too low of a setting, it will blow cold air after the furnace has shut off. From what I guess of your explanation, your furnace is not producing any heat and the room air blower runs blowing cold air. You may have two issues happening. Make sure your thermostat is calling for heat by setting it to a high setting. Inspect the thermostat to see if it is set at Auto. Go to the heating system and inspect it to see if it is heating. If you can't view any flames carefully touch the exhaust pipe and see if it is hot. If not, you have a no-heat condition. A 23 year old furnace may need some TLC so call a technician you trust. He/she may need to replace the ignitor or thermocouple to get it going. They will also check out why your fan is running when it should not.
Nov 02, 2009 | Heating & Cooling
I have a carrier 58RAV095-12 the exhaust fan will run for about 20 to 30 second when you first turn the furnace on then just shut off. Is there a way to check if the ignitor is working before going and...
Normally the Ignitor is easily removed with 1 screw....be careful its very brittle and obviousy turn the power off first...you likely will see a very small crack in the ignitor and a "Hot spot"...it may also be defective even though it's not cracked...the best thing to do is unplug the ignitor and recycle the furnace checking for 120 volts at the Ignitor shortly after the fan starts and before it stops...If you have 120 volts and the ignitor isn't lighting up then it's defective....if you have no power to the ignitor it is something else and requires more info...look for an error code (Lights flashing on the circuit board)
Oct 26, 2009 | Carrier 38BRC048 Air Conditioner
Miller furnace model M3RL080 BW, code flashes open limit switch or external load on W, I bought a new limit switch, the furnace runs for 5-10 minutes then the flame goes out, the blower keeps running and...
Check your furnace filter any Limit fault code usually relates to airflow...Not enough...causes the furnace to run too hot and shut off....the furnace can be too big for your house if its new...the ductwork can be too small , also make sure your return air vents are clean and unobstructed . Your furnace can be running too long a cycle ....also if you have central air conditioning the coil for the AC in the Furnace can be dirty...restricting airflow...if all this seems ok you can usually increase the fan speed or try tunning the fan in the "On" position on your thermostat this will promote better circulation
Oct 25, 2009 | Heating & Cooling
Apr 09, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
