Question about Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
Why won't my tablet turn on?
Charging & reset
Here's what I did...my daughters irulu suddenly wouldn't turn on, although it hasn't been used much in its short life, I suspected maybe the charger port was messed up, she is 7 and quite rough on electronics. So I took the back off carefully, you will want to be careful as well if you try this because of the tiny wires connected to the speaker on the back. Then I found the two thicker wires that come directly out of the battery pack, these are connected to the board. My thinking was that if the charging port was messed up I could wire in and charge the battery directly. So then I cut the plug that normaly charges it and touched the frayed end to the wires that come from the battery, hoping I had got the positive and negative right, I thought the white striped cord would be positive and the solid black wire to be negative. I was wrong and when I touched it, it sparked a little, I was like o no, for sure I had fried it. Then I swapped them taped the wires Down and hit the power button low and behold the thing turned on, I kept the wires taped down for a good thirty minutes then un hooked them, it stayed on..then I snapped the back cover back on, reconnected the plug to the wires. Plugged it in the charging port and it started charging, no problems so far. I dont know if switching the wires on accident reset somthing, or if doing this just jumped started the battery.all I know is that I works now and my little girl is happy.
Posted on Jan 29, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
Damaged charger? Damaged battery? Damaged Screen?
Try charging it for 8 hours. Stick a pin or paperclip in the rest hole and hold your breath.
Posted on Dec 16, 2014
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kindle Fire Won Charge Fix
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My Kindle won't turn on.
sounds like you did everything right
could call amazon see if they can help
or do a factory reset to eliminate software problems you will lose all your data
then there is hardware problems dead battery that won't recharge bad cable connection inside kindle
Jul 04, 2015 | Amazon Kindle Fire HDX 7
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
How to reset kurio tablet? Won't turn on at all
my kurio tablet wont turn on, i have tried charging it and turning it on , and answers on google
Jan 25, 2013 | Tablets & eReaders
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Brand new archos arnova 10 tablet. It is stuck on the charging screen. Won't turn on or off. Have hit the reset button. Didn't help, continues the same problem?
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Oct 16, 2011 | Archos ARNOVA 10 Android Tablet
Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
139 people viewed this question
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
