Question about Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
How can I fix error code 3251 on a Konica minolta c6500 bizhub pro
There is no paper jam. I/O check on sensor ps17 seems fine.
5 Suggested Answers
firecontrol7
  • 6359 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
SOURCE: konica minolta c450 error code c-3752
c-3752
Posted on Mar 31, 2011
SOURCE: konica minolta Bizhub C6500 error code 2424
Hi, I have a C6500 Bizhub pro, but, recently displays an C2404 error. I need to print an urgent job and y can't!
Please helpme!
Posted on Sep 15, 2011
sinclair_cum
  • 38 Answers
SOURCE: konica minolta bizhub pro c6500 error c2452
i have checked all those parts and tested them with a multimeter and there seems to be no problem is there any other way i can overcome this problem
Posted on Nov 15, 2011
Sir canon ir3570 duplex paper jam jam code010d jamtype ps17 deleay sensor
Check the Clutch on the back side.
  1. Clean the all sensors in duplex.
  2. If problem persists Replace Clutch.
  3. If problem Persists Replace Dc controller
Jun 21, 2016 | Canon ImageRUNNER 3570 Copier/Printer
Error code 6508
Could not find a Error code c-6508. But I did find a paper jam 65-08. Check you document feeder there is a jam paper or sensor problem (PS302).
Mar 23, 2015 | Konica Minolta Bizhub C 6501 Color...
Error code C-2704 mean on C6500 Bizhub Pro
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
My best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Dec 30, 2013 | Konica Minolta Bizhub Pro C6500 Color...
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
HP 1010 , paper jam near fuser assembly.
Remove left,right,top & back cover, #check paper sensor flag & flag spring, found any dis location? correct it.Most of the cases spring dis location observed (see the snap shot for easy recognition)#clean fuser paper out sensor as well as check sensor flag.#check fuser teflon sleeve.
Mar 22, 2012 | HP LaserJet 1010 Printer
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Konica Minolta Bizhub Pro C6500 Color Copier Color Printer Logo
186 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
