Question about Whirlpool WTW6400SW Cabrio Washer
Has anyone had the glass top just popped off and is this a common problem?
The glass top just one day popped up in the corners and it makes it tough to close or open. Has anyone had this problem and is it a recall item.
  • 43 Answers
Yes you would have to open the top cover and tilt it back to be able to get to the lid holder that breaks. Holders are at each end of lid. Labor will cost you if you call a repair company to replace those little weak holders. You may be able to do it your self. Good luck.
Posted on Nov 18, 2015
Popping in the front end
it is tough to say without seeing it but it could be the constant velocity joints which are the favourite place for this noise when turning,it could be the wheel bearings,a sticking caliper,a strut,that has a faulty top plate or worn tie rods inner or outer,ball joints,or broken sway bar connectors,or simply a loose wheel.
Dec 04, 2011 | Cars & Trucks
PS3 will not play dvd all i get is the hour glass thing in the top right hand corner
This is the 2nd most common problem with PS3's. This isn't a bad problem. Your laser/lens will need to be replaced. Do you see the time clock (hour glass) in the top right corner going around and around? If so, you are just having laser/lens problems.
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
New windshield installed now making popping and cracking noises .This second one ,and still doing the same thing.
you may have to go to a different place and have them remove the glass or look at it to make sure it was seal good and the glass was sitting in there right give these websites a try www.alldatadiy.com and www.autozone.com wish you the best of luck Michigan Man.
Feb 23, 2010 | Chevrolet Monte Carlo Cars & Trucks
Same problem - just starting in one corner
This is a very common problem, I have had the same issue recently and looking at various forums so have many others.
Audi surely know about it but until everyone makes a stand we will continue to pick up the bill.
Maybe you should gather as much of this proof as possible and try and get some goodwill from Audi.
Jul 03, 2009 | 2003 Audi A4 Cabriolet
Broken glass top on my Maytag Schott Clean (upper
u have to replace the whole top and its about 400 to 500 dollars just for the part cheaper to buy new
Mar 20, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MONITOR LIGHT STAYS BLUE, BUT NO PICTURE
Hi
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it may be the inverter has gone bad. Inverters are like light bulbs and have life expectancies on the capacitors.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
To get to the inverter:
Remove the stand.
Take the screws out of the bottom rear edge (these hold the front trim)
The the trim then unsnaps. {Be aware of the wire to the power button board on the bottom corner}
Start at the bottom and release the trim by lifting away from the glass of the screen from the center outwards to the corners, then work your way up each side bottom to top (a pocket knife or thin putty knife will help release the catches) These sides can be really tough to pop off especially the last top clip on each side.
Then unsnap the top edge (rocking it while lifting helps)
Disconnect the power button plug or unsrew the screws.
Once trim is off, remove the 4 corner screws that hold the screen in. Then the screen will lift up.
unplug the bulbs and wire to the screen (screen plug that goes into the metal case pulls out)
then the inverter is under the center area under the metal cover
Shout if you need more info.
If you email me a good picture of the inverter , I may be able to get a better idea if it is the inverter from a visual.
Fran
bammbamm@ptd.net
Dec 13, 2008 | Gateway FPD1975W 19" LCD Monitor
HP 2210 has a problem with the inside of the glass so photo/doc are fuzzy and unclear when scanned. Is there a way to clean the inside of the glass?
there are 3 screws, one's at the left side of the unit on the top corner (this is the one that's visible), the other 2 are under the silver cover, which houses the dial panel and the LCD, in order to remove the panel you have to use a flat head screw driver or something like that, and pop out the dial cover starting from the top right corner then the left side and eventually the bottom part, and then, using something that can fit through the square hole near the bottom of the dials under the cover which you've just removed, press the lock inside and simultaneously pull(slide) the panel towards the front of the unit, there then you will see the two other torx screws
Good Luck
Mohamadreza
Dec 10, 2008 | HP PSC 2210 All-In-One InkJet Printer
The glass for the scanner broke, i need another one
Eek, that's a tough call.
I think the cheapest would be to take the measurements and have a local glass company cut it to size.
I've never seen a manufacturer offer replacement glass tops for their scanners. The model isn't listed, but it's probably going to be cheaper to either buy a new one or buy a broken one off ebay and take the glass out of it to use in yours.
Dec 06, 2008 | HP Officejet 5510 All-In-One Thermal...
Bell & Howell Copiscan Spectrum corner problems
It can be a nightmare to find out what is causing the dog ear page or folded page at the corner. Check your glass **** inside the scanner to make sure its seated in the scanner properly. The big one is the check the metal paper guides in the scanner paper path. If a guide is bend it will hook the paper and cause it to fold over.
Oct 15, 2007 | Bell & Howell B we Bell & Howell Spectrum...
Whirlpool WTW6400SW Cabrio Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
