Question about Singer 8280 Mechanical Sewing Machine
Machine not rotating - Singer 8280 Mechanical Sewing Machine
  • Debbie Dec 11, 2014
    Hi janice raju, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Reverse button won't work. Anh trouble shooting tips?
This button simply reverses the action of the feed dogs of the machine. Remove the thread plate and all the mechanism (bobbin, bobbin holder, etc) you can in the bobbin area. This should give you a better view of the operation of the feed dogs. Rotate the machine with the hand wheel to see how it operates. Continue rotating the hand wheel and push the reverse button. See if you can spot what's preventing the feed mechanism from reversing its rotation. Hopefully it's as simple as material or thread buildup in the mechanism.
May 29, 2015 | Sewing Machines
Bobbin shuttle doesn't move
Look in your book.
- There is a bobbin (clear plastic) it rotates.
- The bobbin fits into the bobbin case (black), it does not rotate.
- The bobbin case is nested into the shuttle which does rotate.
There is no bobbin shuttle.
Aug 19, 2014 | Brother CS-8060 Computerized Sewing...
Fix bobbin tension
A couple questions. 1. Is the needle in correctly? This is the most common error. 2. Is the top thread threaded correctly? 3. Is your machine an old singer with a broken hook gear? Put your finger on the rotating hook, press and hold, turn you hand wheel AWAY from you and see if the hook stops rotating at some point in it's rotation. That would be a broken gear.
Apr 07, 2014 | Sewing Machines
Singer sewing machine bobbin case keeps moving causing the needle to break.
Is this a front loading bobbin or top? If it is a vertical front loader with the little metal bobbin case, the metal case has to be lined up and snapped firmly into place. You should hear it snap and lock into place.
If it\'s a horizontal or top loading bobbin, and the plastic bobbin "tray" is rotating, then it may not have been nested in properly, before replacing the plate, or may be "jagged" somewhere... If there is a burr on the casing, or as in the case of one machine I worked on, still have a piece of needle stuck in it, the thread will snag on it before it finishes rotating and the rotating motion catches half way and will jerk the case right around and the next stitch will break the new needle.. Those plastic bobbin "trays" are usually easy to find and replace if they have become too burred to use. I have also sanded them smooth again as well though.
To test it, unplug the machine, thread your machine on top, but leave off your bobbin lid and leave out your bobbin, hold the top thread (like when you are about to crank to pull up a bobbin loop) and hand crank toward you, or counter-clockwise one complete rotation. Watch to see if the top thread is caught by the rotation hook and slips all the way around and back over the top of the bobbin tray, or if it snags on it somewhere.... Good luck!
Jan 15, 2014 | Singer Sewing Machines
How to rotate a design that is to big vertical, will fit hortiz. on a singer future 6000.
Isn't your fabirc big enough to hoop it vertically, but stitch it
horizontally?
Do you own a Singer PSW? Easy to edit with this program.
Or you should be able to do in your Singer XL-6000 conversion tools.
Failing that you can rotate a design in the machine itself, simply on the machine by touching the hoop tab on the touch screen (second icon from the right) and then selecting the rotate icon (second from the top) then rotate the design?
Although I have known some designs to not rotate - due to the needle positions during the sewing and jumping process.
Hope some of these ideas are helpful to you.
Aug 19, 2013 | Sewing Machines
Slow Machine
it sounds like the machine needs to be checked at a sewing
machine repair shop, to see there is anything wrong with the
gears or other parts & also to be regreased & oiled
Aug 23, 2012 | Singer 2263 Mechanical Sewing Machine
Elna SU purchased in 1977 jammed; rotating wheel is unable to move forward
it sounds like the machine needs to be serviced at a sewing machine
shop
May 05, 2012 | Elna Sewing Machines
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Apr 08, 2009 | Consew 206RB
Pfaff 2040 Tiptronics bobbin case rotating out of position
Sounds like you need to put a drop of clear sewing machine oil in the raceway of the hook. Then sew on some scrap material to soak up the excess oil.
Mar 10, 2009 | PfaFF Tiptronic 2040
.Editing Patterns
the rotate button uses the 90/180/270/360 formula..seems you'll need to rotate it a full cycle to get it to behave the way you want..here's the link for the manual, if you don't have it.
get the adobe reader first here.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SE_270D_EN_199.PDF
Feb 14, 2008 | Brother SE-270D Computerized Sewing...
Singer 8280 Mechanical Sewing Machine Logo
88 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
