Question about Asko Dishwashers
Asko 5152 dishwasher door "clunks" when opening and closing. What is that?
Door makes clunking noise at half way point opening and again when closing.
  • Asko Master
  • 3,368 Answers
Probably nothing serious, but something is slipinga or catching on the door hindge.
Posted on Dec 11, 2014
Beko de2542f dishwasher
If you live in Rancho Cordova, CA and need dishwasher repair service call us at 916 823 3070 or visit our website Dishwasher Repair Rancho Cordova 916 823 3070 GE Maytag Ken
Sep 03, 2017 | Beko Dishwashers
When the freezer door is opened and closed it makes a "clunking" noise - what is the problem?
I assume this is a side by side. They have closing cams on the bottom of the door. These can waer out and the door will clunl when closed. Some older refrigerators had a mechanism in the dorr itself.
Sep 11, 2014 | Refrigerators
Dishwasher door drops suddenly on opening
Most likely one side or the other has a bolt or fastener that gave away. You will have to take the door off to see what is going on in there by the hinge point.
Jan 11, 2014 | Electrolux EDW5505ESS Built-in Dishwasher
Still turns after opening door
When the door is closed the switch will close, allowing power to circulate through the rest of the circuit. When the dryer door is open the switch will open, breaking electrical contact to the neutral connection of the circuit and stopping the flow of electricity. so it sounds like a bad dryer door switch.
Feb 02, 2012 | Frigidaire Dryers
When I open or close the back door on my saturn vue it makes a clunking sound. How do I open up the inside pannel to take a look
Assuming you have no trouble with the window coming off the track and no kids to drop junk inside the door, is it possible that the clunk is the lock getting sticky? Try putting a little WD 40 on the door catch and close and open the door a few times to see if that makes a difference. If it does, make a lasting fix by adding a few drops of 3 in 1 oil.
Jan 13, 2010 | Saturn Vue Cars & Trucks
Our new LG dishwasher makes loud clunking noise
I believe this is a brand new dishwasher. Please listen carefully to determine of the sound you hear (clunk) is being made inside the dishwasher or is it being made near by. Most times, the problem is that the hot water pipe is baking the noise when the dishwasher closes the water inlet valve ... and the pipe goes "clunk"
I have not had an LG dishwasher make a clunking sound inside itself when the cycle changes. Also, because this dishwasher is so very quiet (well insulated) the pipe banging would be louder than something inside the Dishwasher.
If you have access to the hot water pipe, listen very near it when the cycle changes for the sound. Follow that pipe (hot water) pipe back and insulate it at the point it is banging. (or get a plumber to evaluate and resolve.)
Please get back to me with what you find, OK?
Good Luck!
Apr 06, 2009 | LG LDF6920ST Stainless Steel 24 in....
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
Dishwashers Logo
88 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
