Question about Head Health & Beauty
Hi can anyone help I'm after a new adjustable comb head for aphillips c241 rasor
  • Head Master
  • 3,382 Answers
Try ebay
Posted on Dec 11, 2014
What does capacitor C241 power
How is anyone to know the answer to this question. ????
What is the model number of the unit in which you are questioning.
Jan 16, 2015 | Televison & Video
My monitor syncmaster 2233sw wont turn on at all ,,,eather the light or the screen what could i do please need help !!
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed, replace them at once.
Sep 02, 2013 | Samsung SyncMaster 2333SW 23" LCD Monitor
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
I have aphillips tv, model number 42pfl7603d/10. The stand which it sits on at base of tv has broke, I'm looking to find where I get a replacement one. My walls will not support brackets for it
The only place I found that has one is in the UK
http://www.ebay.com/itm/TABLETOP-STAND-FOR-PHILIPS-42PFL7603D-37PFL7603D-37PFL5603D-42PFL5603-LCD-TV-/360506039050?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item53efd59b0a
Dec 06, 2012 | Televison & Video
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
Does anyone know if the L37G10A supports PAL I as well as PAL B/G. I'm moving from Australia to UK and am wondering whether to bring the TV
Screen Type LCD Panel Type IPS-alpha Progressive Full-HD LCD Panel Panel Aspect Ratio 16:9 (Widescreen) Aspect Ratio Control Modes (TV/AV modes) 4:3, 14:9, 16:9, Just, Zoom1, Zoom2, Zoom3, DTV: 16:9 & 4:3 Full Aspect Ratio Control Modes (PC mode) 16:9, 4:3 Comb Filter Yes Progressive Scan Yes TV Tuner Receiving System DVB (Digital), PAL-B/G (Analogue) Tuner Type Integrated SD/HD DVB-T 7MHz Australia, PAL B/G
Contrast Ratio 1 - Dynamic: 20000 Picture Adjustment Modes / Film Modes Normal, Dynamic, Cinema, Eco Colour Temperature Control Cool, Standard, Warm
May 21, 2011 | Televison & Video
The clippers are back together but are cutting the skin and still dont sound right did i put them together right.
Did you remove the comb and blade only? If so, the comb (the part that doesn't move and is closest to the skin) should extend beyond the reach of the blade (the part that does move left and right). Nicking is sometimes caused by excessive pressure against the skin. A properly adjusted blade will resemble someone with an underbite (extended lower jar) with the comb part extending beyond the blade.
Most clippers have a clatter adjustment screw. Turn this until the clipper clatters (buzzes really loud) and then adjust it back until the clatter stops (but not too far or you will lose power and the blade will stall or cut slowly). Be sure to oil the blades. Mineral oil (from a drugstore) will do if you can't get shaver oil.
Good luck from Detroit, MI
Apr 29, 2011 | Vacuums
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
I don't care for the plastic comb guides on the 8554
Only by extending the blade with the lever at the side, the only other thing is to use a large headed regular comb and gold it away from the scalp to the length that you desire then use the clipper to cut off the hair. I am a hairdresser and very rarely use the providede attachments
Jan 04, 2009 | Wahl 8554 Hair Trimmer
Health & Beauty Logo
44 people viewed this question
Top Head Health & Beauty Experts
rugby prop
john h
Are you a Head Health and Beauty Expert? Answer questions, earn points and help others
