Question about Hardware & Accessories
HOW DO I SET MY ET7-AL DELTA 7 DAY ELECTRONIC TIMER
Show how to set the itermatic et821c
Following link has manual for Intermatic ET8100 series
Choose astronomic dawn-dusk timer -or- 7-day programming
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET8000
be sure to install two AAA batteries in compartment located on front just below the buttons.
Also reset the timer prior to programming ... and this will clear any conflicts or prior programming.
Timer default voltage is 120 volt AC. Choose 208-240-277 volt by moving selector switch located on back of timer.
Gene
Water Heater Timers Save Money
Jan 17, 2014 | Intermatic ET8215C- 7-Day Electronic...
I have two Delta 7 day programmable timers which I cannot programme ET7-AL
These are scans of the original packaging. Hope this helps. FYI mine packed up after a couple of years but is now working after I unsoldered and replaced the Troily 1.2v 40mAh (5.5mm x 12mm) button cell
Nov 16, 2011 | Hardware & Accessories
The instructions are not very clear on my new UPM ET420C Electronic Outdoor Timer. What I want to do is have the time turn on power everyt morning at 3am, run for 2 hours, and stop at 5am. Could you tell...
Using the right & left arrows, go to CLOCK to set the current time & day.
Press SET
Using arrows, set the day, press SET.
Using arrows, select the hour, press SET.
Select the minute, press SET.
Select the second, press SET.
Using right arrow, press once for program 1.
Press SET.
Select day, press SET.
Select hour, press SET.
Minute, SET.
Repeat this for every day you want this program, five days or seven days,
Programs 1-5 or 1-7.
Gary, good luck, these instructions are difficult.
May 27, 2011 | UPM Programmable Outdoor Timer
I need to know how to set my timer, I've had it for a while but i don't have the instructions that came with it. Day-Timer Mwave Tx12626x Timex Electronic 7 Day
Open following link to identify timer for sure.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
Several companies sell a similar timer, and there is a manual for Westek version.
http://waterheatertimer.org/pdf/Westek-TE05WHBL-manual.pdf
Add a comment if this manual is correct for the Timex also.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 01, 2011 | Day-Timer Mwave Tx12626x Timex Electronic...
Looking for a timer to turn a 120volt 2amp water pump on for 1min 2 times aday that will last for more than 3 years please help
1) You need 120V timer to control 2 amp water pump.
V x A = watts so 120V x 2amp = 240 watt
754 watts per HP divided by 240W = 1/3 HP horsepower.
2) To get 1 minute time periods, you need electronic timer.
Most electronic timers have minimum 1 minute set time.
Same schedule each day, you can use 356-day, 7-day or 24-hour electronic timer.
3) To have electronic timer last longer than 3 years you need a clean circuit and expensive timer.
Use circuit analyzer to check circuit. Hire electrician to check circuit and replace pump if necessary to make sure timer will last as long as possible.
4) Intermatic ET70115C should last for many years. Battery is replaced every 8 years.
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
ET70115C $379
http://www.1000bulbs.com/product/3391/ELEC-ET70115C.html
5) You posted under EH10 water heater timer, which is inexpensive water heater timer rated for 1HP. You can't expect inexpensive timer to last as long when using a motor, although 1/3 HP is lightweight motor.
6) You can buy five EH10's for same price as one ET70115C.
7) List of ordinary electronic timers, each with slightly different features
Intermatic EH10 $73
http://www.amazon.com/Intermatic-EH10-Electronic-Heater-Indoor/dp/B000GHIPOA
Intermatic ET1105C $96
http://www.amazon.com/Intermatic-ET1105C-Hour-Electronic-Switch/dp/B002X1FYWI
Intermatic ET101 $101
http://www.westsidewholesale.com/24-hour-programmable-electronic-timer.html
Tork EW100B $177
http://www.1000bulbs.com/product/8434/TORK-EW101B.html
Sylvania SA300 $72
http://www.amazon.com/Sylvania-SA300-120-Volt-Single-Pole-Industrial/dp/B000KKNEO4
8) See wiring diagrams and manuals for some of the timers listed above:
http://waterheatertimer.org/Boxtype.html
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 31, 2011 | Intermatic 7 Day Electronic Timer Eh10...
How to set timer
Open following link for misc Timex manuals.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Nov 28, 2010 | Day-Timer Mwave Tx12626x Timex Electronic...
TIMER IS WILL NOT COME ON FOR THE TIME IT IS SET FOR.
This 7 day timer is not a precision device. The resolution on this timer is very low and almost impossible to set with precision.
If your requirement is to have the load come on at an exact time you may wish to consider an electronic type of 7 day timer.
Mar 04, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Hardware & Accessories Logo
238 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
