Question about Kyocera Mita KM-2050 Printer
Wen the machine is ON programing loading will appeare.programing loading displaying.m/c cannot be show ready to copy
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
I AM AFRAID THER ARE MANY REASONS FOR THAT AND ALL OF THEM ARE BAD.
PROGRAM LOADING STUCKING NEED TO CHECK THE CHIP OF THETOUCH PANNEL FIRST .THEN THE CHIP INSIDE THE MACHINE .AT LAST THE MOTHER BOARD. IT WILL NOT ANY THING BUT THOESAND ALL ARE EXPENSIVE AND NEED ATECHNICAL HAVE THE SYSTEM TO REINSTALE IT AGAINE
Posted on Oct 16, 2015
Copy Machine is running ready but can't print and copy.
The paper tray is not placed properly leading to erroneous sensing place the paper trays properly
Jun 22, 2015 | Canon ImageRunner 4570 | IR4570 |
Maintenance manual
When you see "optimizing performance", the machine is going through a cool down cycle and will return to ready after the machine's internal temperature reaches an acceptable amount (usually appears after a large amount of copying). Sometimes I have seen it take as long as 5-10 minutes for the message to clear but if you turn it off before it finishes it's cool down cycle, most of the time the machine immediately shows the message again on display. As mentioned, make sure your filters are clean. I'd also check to ensure your exhaust fans are operational (especially those near fuser area), fuser thermistors clean and in proper position, and ensure machine has proper clearance around the cabinet so it can breath properly.
Jun 17, 2013 | Cars & Trucks
My machine show a 01 and a flashing key I try to do hold a button for 5 sec to deactivate but time tab it's not reacting with at is the prob
Your washer is in the "child lock" mode, hence it won't allow any program. Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. If nothing is pressed within 10 seconds.following this the menu will close and it will default to program in the display. Once you see that in the display, press the "select" button until "CHILD LOCK :OFF" appears in the display. Finally by pressing the start/pause button the key symbol should disappear - confirming you have successfully exited the child lock program.
Pl click if helped.
Mar 14, 2013 | Bosch Classixx WFL 2066 Front Load Washer
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Which numbers can i press when i get error c-6, 400 om a KM-1620 photocopier?
Put the machine on and press 1087, 1087 until the display shows U000. Press 163 and the press start .display shows CLE, press start again. The machine will initialize and become ready for copying
Nov 15, 2010 | Kyocera Copystar CS-1620 Black and White...
Hi , i have tried what you mention for hb88rc let say i am doing the programing and it is currently 10 am. (example) i want it to be on at 7am and off at 7pm for the entire week i do as the instruction...
You happened to catch the same guy that answered before.
Lets go through the exact programming steps:
Your schedule is ON at 7am and Off at 7pm ALL week.
1) Set the clock to current time:
Hold down clock button while doing next steps
Press Hour button until correct Hour am-pm shows (10:00am for example)
Press MIN button until correct minute shows.
>>> Now wait, the manual seems to leave off a step here... it doesn't say to enter current day.
OK, lets make sure current day is set.
I guess you press Day button until current day shows.
Now release the clock button.
2) Program the timer to your schedule:
Press and release PROG button.
press it once and Program1 ON is ready to be programmed
The screen looks like the picture below:
3) Ready to set Program1 ON:
The display shows the number 1 and it shows the word ON.
Press DAY button as many times as it takes until all days show at top of display.
Press Hour button until 7 am shows in display
Double check that the time is AM
Press MIN button until :00 shows in display
4) ON time for Program1 is set
We are ready to set OFF time for Program1.
5) Press the PROG button until the display shows Program1 OFF just like photo below
Notice that the number 1 and the word OFF appear on display
6) Ready to set Program1 OFF
Press Hour button until 7 pm shows in display
Double check that the time is PM
OFF time for Program1 is set
7) Programming is complete, and we are ready to use the timer
(If you want more programs, press PROG button until program2 ON shows in display)
8) To exit programming, press the CLOCK button.
Current time show in the display.
The timer should be operating correctly now.
Add a comment, if you want to contact me directly.
Nov 09, 2010 | Intermatic HB88RC - 7-Day Programmable...
Washing machine shows key on the display and won't start
Hello, Welcome to fixya.
The Key symbol means the lock has been activated some how.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Oct 20, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Restore computer
Before doing anything start your PC and keep pressing F8 slowly. A screen will appear with options choose Last Known Good Configuration to see if it cures your problem.
Aug 19, 2008 | E-Machines eMachines Desktop PC
Kyocera Mita KM-2050 Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
