Question about Samsung Computers & Internet
Can i use 1 TB in P4BP-MX?
My Motherboard P4BP-MX NOT recognize Samsung 1 TB HDD Model HD103SL Is my Motherboard exceeds its LIMIT? I am using IDE - SATA Converter for this.
    Sergeant:
  • 231 Answers
Purchase a $20 external USB drive case or SATA Card at Frys.com and install it.
Your OS needs to support the size also. The Firmware on the drive may not support the slower speeds also.
Posted on Dec 24, 2014
  • 22 Answers
SOURCE: SATA connection
Do a Google search for "SATA adaptor for laptops". This should point you to available SATA to USB adaptors. Haven't clue how well they work, but they are out there
Posted on May 30, 2008
  • 1257 Answers
SOURCE: SATA HDD not working
Avinash thaks for providing the exact error..
Re: A Disk Read Error Occured. Press CTRL ALT DEL to restart
1 - Have you tried a different IDE cable?
If not give it a go and do a repair if needed again!
2 - You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
3 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
4 - or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!! Good Luck D.i.l.i.p
Posted on Jul 02, 2008
SOURCE: sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Posted on Mar 17, 2009
bob_computer
  • 3153 Answers
SOURCE: new Samsung HDD hangs up with boot
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
If it IDE make sure that the master / slave jumper is set correctly and also double check your power connection
Posted on Sep 22, 2009
  • 76 Answers
SOURCE: 500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Posted on Apr 08, 2010
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
IDE HDD on p5gc-mx+1333 as Master?
If you are having issues with BIOS passwords, you can reset it using the jumper on the motherboard.
You can connect that with an IDE cable.
Jul 27, 2012 | ASUS P5GC-MX/1333 Motherboard
I Need Vga Driver For Asus p4bp-mx
Normal 0
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Sep 27, 2010 | ASUS P4BP-MX Motherboard
Where can i download driver mother board P4BP-MX? non use program
Go to:
Then select "motherboard" "Socket 478" and then P4BP-MX (or 2.0 depending on which you have). Then select your OS, this should take you to a screen with the available drivers.
May 04, 2009 | ASUS P4BP-MX P4 Prescott/845GV/FSB...
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Sound drivers i had a need of it
hi there i found the drivers on this site and i can download and pass it to you thru ur email or not i could give u the website of it
by the way there are two versions of ur mother board : ASUS P4BP-MX or ASUS P4BP-MX 2.0 so pls tell me which one and i could forward the driver for u or like i said i could give u the website and just place in ur motherboard model
but if ill send it thru mail the drivers it will be in two batches coz yahoo mail is 10 mb is the maximum
here's the website for ur asus: http://www.asus.com
or you can email me on to my account : nokiaboy3530@yahoo.com
God bless
May 30, 2008 | ASUS K8V-MX Motherboard
Computers & Internet Logo
67 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
