Could it be my has the Clicking sound? It does not start when you press the remote to turn it on.
Turned power off at wall. Changed batteries in remote. Listened to it clicking & pausing. but not coming on.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 11, 2014
SOURCE: Toshiba Plasma clicking noise
Check the fan, it may be dust or a bad bearing.
Posted on Oct 10, 2007
  • 2318 Answers
SOURCE: insignia tv will not turn on [ power up]
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 19, 2008
SOURCE: Press power, it clicks but nothing then clicks again as it turned off.
some body please help tell us whats up. getting old
Posted on Jun 29, 2009
SOURCE: cliking sound when trying to turn on tv
it still click on/off but now wont come on
Posted on Jul 22, 2009
  • 60 Answers
SOURCE: Samsung ps-42p2sb Tuner never turns on.
  1. Might need a service technican to fix your set might need a new power supply or if you have any electronics backround take the back off and look to see if there are any bulging capacitors on the power supply
Posted on Aug 23, 2009
Garage door opener wall panel light flashing
the lock is turned on. On the wall switch press and hold it for a count of 5. the light should stop blinking
Sep 26, 2016 | Building Materials
Casa Vieja ceiling fan w/remote; worked well. Then wall switch was turned on/off, chains pulled. Everything working: fan high, med and low, and light on/off/dim - except now fan won't turn off !
The chain pulling and switch flipping causes the simple logic in the remote receiver to become confused. Your only hope for restoring normal operation (short of replacement) is to disconnect power at the source, then remove remote battery and press all buttons to eliminate "stuck button" problem. Reconnect power and test operation using only the remote. If normal, you will have to decide whether to disable pull chains, wall switches, or both. If not normal, you will have to try an infinite number of combinations of pull chains, wall switches, and power on-off to get things back to normal.
Aug 11, 2016 | Casa Vieja Dryers
The vizio set will not respond to remote to turn set on.
Point the remote at your cellphone camera and press a button. You should see a flicker from the remote if it is working. If no flicker then remote is defective. If you have a flicker then the problem lies in the t.v. could be the receiver or another issue in the t.v.
Jul 21, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My remote lights up when you press the button but it's not controlling my fan.
Controlling a ceiling fan/light using a wall switch causes the remote control to lose its memory. You will have to start all over at the beginning. Remove batteries from the remote, push all buttons to eliminate a stuck button as a cause, then reinstall batteries but do not push any button yet. Be sure all wall switches are off. Go to the power source for the fan/light (not the wall switch) and turn it off. Wait briefly, then turn on the power at the source again. Try remote operation. If successful, use only the remote to control operation. Forget about using the wall switches.
Dec 21, 2013 | Dryers
I have no sound on my R61WH76?
make this adjustments and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
  • Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
Nov 03, 2013 | Televison & Video
A light bulb in my ceiling fan burned out the other night when I turned it on with the remote. I changed the bulb, but since then the remote will not turn the light on or off. The wall switch will, and...
Sometimes all you need to do is switch the wall switch on and, off a few times while you press the lamp button (off press the button then: on press the button) no go? then: check or, replace the hand remote nine volt battery. still no go? then:
Check the wattage of the replacement bulb; some high wattage bulbs will rob power from the remote unit. didn't work? OK,
next turn off the power to the lamp and, open the lamp cover: you will see a large plastic rectangular box (the reciever) open the cover on the box and, you will see a block of tiny switches then: open the hand remote battery case it too will have a block of tiny switches these must match i.e. 1,3,5,= on 2, 4, = off both the remote and, reciever box. Barring that ...you'll need a new reciever for your fan.
Jun 01, 2010 | Hunter 27187 Remote Control
When turning on the t.v. makes a clicking sound (Normal sound) but the t.v. doesn't turn on, no picture?I am wondering if the t.v. has a reset button or something?
Does any indicator light in front of the TV when you turn it on?
if the answer is yes, try turning on the TV by using the remote control. press any of the programme numbers 1-9 while pointing the remote at the TV. It is advisable that you install new batteries in the remote before attempting this.
If the answer is no then you should do the following:
- check the wall socket. try plugging another device into this socket to see if there is power present
if all the above fail thentake the TV to the repairman.
Oct 02, 2009 | Televison & Video
Guages when crazy. Now won't even try to start.
You likely have it repaired by now but it sounds like a classic case of oxidized battery or cable connection (sometimes mis-diagnosed as bad battery but cured with new (clean) battery)
Feb 25, 2009 | 2002 Jeep Grand Cherokee
Remote start (posibly)
Your battery is almost certainly flat.
When you start the engine, the starter motor takes a large bite of power out of the battery. It takes a long time to put that power back.
So, you tried to start with remote start and it did'nt fire up. This took a big bite.
Then you started manually. This took another big bite.
The engine started though, and the alternator began the mamoth task of putting two start attempts worth of power back into the battery.
After 5 minuites, you interupted the alternator and switched off.
Now the battery will be really ill!
You really need to get a jump start from a vehicle with a battery which is about as big as yours.
Connect the leads from the good battery to yours, making sure that the donor vehicle is running. Then walk away and have a coffee. Come back and try your truck again. It should start ok.
If your battery has done this even once, can it be trusted again? If its more than 3 years old, get a new one fitted.
Hope this helps!
M3ODQ
Jan 31, 2009 | Directed Electronics 1100f Ford Pats...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
