AR-5127 sharp we change the developer after changing the developer copy is going light
  • 61 Answers
SOURCE: Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Posted on Nov 28, 2008
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
  • 30 Answers
it is a heater code. The thermostat has blown and resetting the code could cause a fire, but it probably won't do anything, the part will need to be replaced
Posted on Feb 25, 2009
  • 253 Answers
SOURCE: Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Posted on Feb 12, 2010
rezazadeh
  • 328 Answers
SOURCE: developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Posted on Jun 01, 2010
How do I reset the toner indicator light on sharp AR 5127
TONER NEEDED LIGHT IS TRIANGULAR, CIRCLE SHAPED MEANS DEVELOPER NEEDS CHANGING, UPSIDE DOWN TRIANGLE MEANS WASTE TONER BOTTLE NEEDS TO BE EMPTIED. THIS BOTTLE IS IN THE RIGHT REAR CORNER OF THE MACHINE GOOD LUCK
Sep 04, 2015 | Sharp Office Equipment & Supplies
Sharp ar 5127 erorr u 2-40
Pl do something as follows (1) Change Toner IC Chip (90%), (2) Check the toner Cartridge. If it wont be done, pl let me know.
Shawn.
Dec 07, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp Fuser
Feb 01, 2009 | Office Equipment & Supplies
Error code sharp 5127
go to percision roller in phx arizona you can get all sharp service manuels i have alos seen them on ebay?
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
Dec 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
It dosent enlarge the document in book copy mode in sharp ar 5320
You can not enlarge when set to book copy since the machine is not able to rotate the image to fit on bigger size of paper.you need a machine with rotation feature like the Sharp ar-5127 with a dual function board.
Nov 15, 2008 | Sharp AR-5320 Black and White Copier
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
29 people viewed this question
k24674
