Question about Uniden DECT 6.0 Cordless Phone ID
My voice mail doesn't work. I cannot get more than 2 rings on my incoming calls.
Using the manual I have worked from the menu key.
  • 21 Answers
Press.MENU/SELECT > Ans. Setup menu > Ring Time submenu
Select a Ring time - Toll Saver, 2, 4 or 6 rings. Press MENU/SELECT once again to get a confirmation tone. The Toll saver setting is for if you are checking voicemail on a Long distance call, the call rolls over to the voicemail immediately if there are new messages
Posted on Dec 13, 2014
Fax won't answer
If you have an answering machine connected to the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated to the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Uniden Dect1560 - For incoming calls it only rings 3 times. Is there a way to make it ring 6 times before it goes to voice mail?
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Jul 24, 2011 | Uniden Cordless Phone
Dell 2135CN cuts-off incoming calls to my home phone number after 2 rings and the call goes to the printer. I hear the ringer inside printer, then hear fax tones, even though the call is not a fax. My...
Hi and welcome to FixYa!
Well if that's the case, the printer should be detached or powered of during call operations. The printer detects incoming calls that's why it triggers it to operate. Turning it off during operation will surely be the solution.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 05, 2011 | Computers & Internet
All incoming calls go direct to voice mail,phone does not ring.
You may have turned the radio off on your phone by activating Airplane mode. This mode will send all calls to your voice mail.
Check your owners manual to re-active your phone to Normal mode.
Apr 07, 2010 | Nokia 6700 Classic Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
BlackBerry Pearl 8130 - no ring tone on incoming calls, can only receive text and voice mail
In your BlackBerry Pearl 8130 handheld go to Profile and then select Advanced, Highlight any one the profile then click on menu key and then select Edit and then select Phone, Then select Out of holster, Press menu key select the tone. You will be able to hear the tone for incoming call.
Oct 18, 2009 | RIM BlackBerry 8700c Cellular Phone
Incoming ringtone length
if you have voice mail, you can set the number of rings before forwarding to voice mail in the administrative options of the voice mail menu itself. Call your voicemail and listen for administrative options. Follow the prompts.
Mar 11, 2008 | Lands Phones
Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Nov 21, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Uniden DECT 6.0 Cordless Phone ID Logo
160 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
