D 1047/ B 817 250 WATT AMPLIFIER CIRCUIT DIAGRAM
FOR REPAIR OF BURNED AMPLIFIRE
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Get new amplifier with bigger capacitor
Posted on Feb 19, 2015
Help me with a subwoofer circuit
sub-woofer circuit Michael, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
100W Subwoofer Amplifier Circuit Diagram Working and Applications
Subwoofer Filter Circuit
22 Watt Car Subwoofer Amplifier Circuit Diagram
subwoofer circuit Google Search
Jun 03, 2016 | Audio Players & Recorders
Peavey dpc1000 service manual
Don't do what Fred said. this is a complicated switch-mode amplifier - you'll need to pass it to someone who knows these.
after you recplace the obviously burned parts, you need to run it up in test mode and go through the test procedures until you find the other faults that caused it to fail.
Jan 24, 2013 | Music
Car amplifier stopped working.
what gauge wire are you using
Apr 24, 2012 | Car Audio & Video
If i buy two 270 watt subwoofers, do i need a amplifire of 540 or above?
Always look at the RMS. If they are 270 watt peak or RMS, you want an amplifier that has about equal RMS.
Thanks,
Lee
Mar 04, 2011 | Sony Car Audio & Video
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Sep 19, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
My PG Xenon 600 watt amp will not power my subwoofers
hello it sounds like your problem may be in the remote/power wire that goes from the back of your radio deck to the amplifier. the amp should have a wire connection that says remote,p.con, or antenna. and its usually the smallest wire connector located by the power and ground wire. this wire goes to the solid blue wire coming out of the deck. you can conect the wires together any way you want. i usualy shave off a little pice of the wire cover and wrap the wire coming from the amp around the bare wire then cover it in electical tape or cut the blue wire from the deck at a fit length and use a wire nut and put the two cut ends in and also the wire coming from the amp. also make sure the amplifire dose not have power to it just to be safe. wouldent want to fry anything.
There is also the left and right wires(ususaly red and white) that go on the back of the deck to the amp.
also chek the volume on the amplifire
Apr 12, 2009 | Phoenix Gold XENON 600.1 600 Watt...
Computers & Internet Logo
328 people viewed this question
David Payne
David Payne
