Question about Samsung HP-R5072 50 in. Plasma HDTV
Why wont the Television click on, when remote is pressed?
Turned off at wall many times. Replaced batteries in Remote, asked 3 people to help all to no avail. Regards Annette
    Top Expert:
  • Samsung Master
  • 74,377 Answers
If it turns On just for a moment; at least, and the standby/power light at its front panel comes ON; and it goes OFF withing seconds; the main board to the set is faulty. If standby/power light at the front panel does not come On; the main power supply regulator board [inside] the TV is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 11, 2014
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Can't find the codes for my emerson tv codes for
Instructions
    • 1Remove the battery cover and insert new batteries into the remote. Press the "Power" button on the television to turn it on.
    • 2 Press the "PRM" button that is in the lower left corner of the remote control. You should see the signal indicator light come on.
    • 3 Click the DTA800 TV Codes link in the resource section to view a list of program codes for the converter box. Enter the 3-digit code for your television by pressing the number keys on the keypad. Press the "OK" button when finished. You should see the indicator light turn off.
    • 4 Point the remote at the television and press the volume keys on the remote control. If the volume for the television changes, the remote has been programmed successfully.
    • 5 Enter another 3-digit code for your television if the first code fails to program the remote
    • CODES : Emerson
      • The RCA Universal Remote has 17 different codes for Emerson televisions. These codes are 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064 065, 067, 075, 076 and 079. There are 18 different Emerson VCR codes. These codes are 008, 009, 010, 013, 015, 020, 023, 027, 034, 041, 042, 047, 057, 062, 065, 067, 068 and 070. There are no codes for Emerson cable boxes.
      Hope this helps. =)
Sep 30, 2014 | Televison & Video
The heater is not displayed on the wall remote.
The modern Life., You'll need some how to track it down. However, are the batteries in the remote Fresh? I mean to ask, how old are they? And, are the sensor lenses clear of whatever?
May 02, 2014 | Heating & Cooling
I have no sound on my R61WH76?
make this adjustments and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
  • Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Use your remote control. The first step is to inspect the batteries of the remote control and see if they are functioning. If its power button starts to blink several times once you turned it on, then the batteries need to be replaced. See to it that your remote control is used within about 20 feet from the television. Make sure also that nothing blocks the space between the remote control and the receiver.
Nov 03, 2013 | Televison & Video
Red power light on but no picture
make this test and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
  6. Verify you are getting cable/satellite in other parts of the house
  7. Verify the VCR is plugged-in,getting power, and turned on.
  8. Verify that all wires are connected to proper place
  9. Scroll through input screen to verify you are watching the correct inputs
Look at the FAQ on the manufacture's website or user manual
Jul 31, 2013 | Hitachi 57F710 TV
Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
Sep 05, 2011 | Universal Remote Control Dish Network...
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online...
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 17, 2011 | Toshiba Se-r0177 Remote Control
I don't know what model my fan is, but it's only 3 years old and suddenly two days ago the light and fan quit working. We replaced the light switch on the wall-nothing. Took apart whatwe could of the fan...
That may be, because you were using the Remote Control to operate it, but then turned off the wall switch instead of turning it off using the Remote Control.
Turn the wall switch back On and try to get the Remote Control to take back over the operation. If that solves your problem, in the future you will know to turn off the fan and lights with the remote, before turning off the wall switch.
Hope this helps solve your problem. My wife had to learn the same way with ours.
Feb 04, 2011 | Hampton Bay Heating & Cooling
The TV does not respond to the remote control. I have replaced the batteries in the remote control
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
May 01, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung HP-R5072 50 in. Plasma HDTV Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
