What is meant by file system: NTFS,FAT32,exFAT? & allocation unit size??
  • Computers & ... Master
  • 3,512 Answers
babygenius55
  • 96 Answers
SOURCE: I can not able to format my Kingston 64gb pen drive
Hello there. you will most likely have to buy a disk utility like partition magic, or some such. if you go to softpedia .com there should be some good free/shareware programs there.
Posted on Nov 28, 2008
laikexpert
  • 281 Answers
SOURCE: I have the 80 gb version and need to reformat it.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Jan 30, 2010
adhiwahyudy
  • 64 Answers
SOURCE: Cannot open file. Access Denied.
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
Posted on Mar 22, 2010
sodeep
  • 3267 Answers
SOURCE: I have a 500gb kingston
connect to a PC and use windows format command to format in NTFS format,
Posted on Jun 26, 2011
clairexiang1
  • 59 Answers
SOURCE: How do I format my
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Posted on Jan 17, 2013
Momery card password
Hello Pradeep.
My solution is the easiest, but will lose you all data stored on the card. By using a Amazon com Belkin F4U044ebAPL USB 2 0 Universal Media Reader Electronics adapter you can insert the card into the correct slot while connected to your computer. Open my computer and on the left hand side where you drives and folders are listed, the card will be listed. Right click on the sd card icon and select format, a new window will pop up and there are a couple of options to check here. 1st on the list is capacity, you can ignore that. Next is File System, you want to select FAT32 (if available) or FAT/exFAT (do not select NTFS, if you do we can fix it but it's a little bit more work). Next is allocation unit size, again ignore this for now. Below that you will see a button called Restore device defaults, click that and notice that your Allocation Unit Size window changed from whatever number it was to Default allocation size. Volume Label, here you can type in a name for the SD card if you like but it is not necessary. Under Formatting options (if checked) uncheck quick format. Then click Start. This erases all data and you should be able to insert the card back into the phone and once again have access. Respond with any questions.
May 03, 2016 | Nokia ASHA 200 Dual Sim Gsm Unlocked...
How to remove write protection from sony hd-e1
PC & MAC use different file systems.
It sounds like your hard disk is formatted as NTFS. NTFS will allow a MAC to read from the disk, but not write to it. You need to re-format it using FAT32 (if your MAC is older) or exFAT(if your MAC is fairly new)..
FAT32 will allow a maximum partition size of 2TB(when formatted from a MAC) and a maximum single file size of 4GB.
exFAT will allow pretty much any file size.
NB:Formatting a hard drive DELETES ALL FILES on the hard drive, so backup whatever is important before you re-format it.
1. Open Applications > Utilities
2. Choose you hard drive from the list on the left
3. Choose the "Erase" tab and choose your desired format (FAT32/exFAT)
4. Type in a new name..Click "Erase"
Apr 10, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
How to refomat from ntfs to fat 32 windows 7
in windows, right click the drive in question and choose "format..." from the menu. in the subsequent window, select FAT32 as File System and default as allocation size. please note that a FAT32 file system does NOT support files that are bigger than 4GB.
Dec 27, 2011 | Western Digital Elements Computers &...
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
Datatraveler is format as exfat. I want it format as ntfs or fat 32??
connect it to the computer and right click on the icon of the drive in my computer and choose format a box will apperar click on the file system and choose fat32 or ntfs then tick quick format and press ok a promt wil appear that all data on the drive will be erased click ok your drivbe will be formatted in fat32 or ntfs file system you want .
but before doing this please make a note that all data on the drive will be lost so please back up data before continuing with format
Dec 06, 2010 | Computers & Internet
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
Cannot copy more than 4gb file on a 500gb external usb hard disk
You have to change your hard drive from FAT32 to NTFS,because FAT32 limits the size of transferred files to 4GB. To do so ,go to Start,right click on Computer and select Manage. Under Storage click on Management.Find your hard drive in the list and right click on it and select Format. Under File System change the Answer to NTFS and leave the Allocation Unit to default. Click on Perform Quick Format if you want.click OK and confirm your OK with losing all data on the drive,and your done.
Regards Bill
Apr 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I need to format the USB I have to a Fat the only options I have are Fat32 NFST and exFat
normally you would format to fat32 that will be compatable with most systems ..... exfat is used only for linux ... but linux can also use fat32 and NTFS .... microsoft can't read exfat without a special program ... you can use NTFS if you hve a very large USB drive ...but fat32 will be compatable with the most systems ...
Apr 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hello, I have a new WD Elements 500mg
If you are using Windows Vista then format your external drive with exFAT (Extended File Allocation Table, aka FAT64), or NTFS. And if you are using Windows XP then only solution is to format drive with NTFS file system.
How to do that, just right click on HD from My Computer an click format.
Oct 18, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Recently bought a Maxtor portable 250 GB HDD, need to format it to FAT32 so that my Playstation 3 can recognise it, but Vista will not allow it, can only format it to NTFS and exFAT. How can i format the...
You must be logged on as an administrator to perform these steps. Before you begin, note that the FAT32 file system has size limitations. In this version of Windows, you cannot create a FAT32 partition greater than 32 gigabytes (GB). In addition, you cannot store a file larger than 4 GB on a FAT32 partition. For more information, see Comparing NTFS and FAT file systems.
blank.gif Converting a hard disk partition or volume from NTFS to FAT32 requires that you reformat the partition, which will destroy any data on it. Be sure to back up any data you want to keep before you begin.
Nov 04, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
