Question about Husqvarna Sewing Machines
How do I thread the cotton for a two reel application on my husky 580?
  • Husqvarna Master
  • 1,860 Answers
If your asking about sewing with double needles, then here is the answer. thread the 1st needle like normal,, then use the other spool pin to start the other spool of thread and then thread the machine the same way you did the 1st needle and then thread the 2nd needle and pull the thread tails behind the needles toward the back of the machine and you should be ready to sew.
Posted on Dec 16, 2014
How do I thread the cotton down to wind a bobbin?
have you tried a youtube video that shows the bobbin winding for machines like your?
Dec 08, 2014 | Sewing Machines
Thread is bunching up in bottom.
It sounds like you have no tension on the bottom bobbin reel. Did you check your tension on the bobbin reel. The tension must be right on both sides. When pulling on the cotton when the reel is in its bobbin case you need to feel a little resistance. Adjust the tiny srew on the bobbin case to tighten the reel to avoid it to turn in the casing.
Jan 11, 2014 | Brother PE770 Computerized Sewing Machine
How to thread euro pro x
Cotton reel on top of the machine, make sure presser foot is up, make sure takeup lever is at the top, take the thread to the left ot the machine going through the guides at the top, bring the thread towards you and straight down and round the big cotton guide and straight back up, right to left through the takeup lever then bring the thread straight down through any guides and then thread the needle
Oct 26, 2013 | Euro-Pro Sewing Machines
I have an old Singer, Model #6146 from the late 70's or early 80's, can't remember when my mom bought it, but I can't remember how to thread it and I don't know how to put the thread on the bobbin. Any...
Cotton reel on top, take the thread from the reel to the left and over the top guide, straight down throught the tension discs, back up to the take up lever making sure the lever is at the top, through the lever right to left, straight down through any guides and thread needle front to back.
To wind the bobbin, reel of cotton on top, bobbin on bobbin winder making sure it is pushed to the left, take the thread to the left and round the small wheel and back to the winder, wind the thread round a few times on the bobbin, push the windewr to the right, and loosen the stop motion in the balance wheel.
Mar 27, 2011 | Singer 2250 Tradition
Needle won't pick up bobbin thread tried cleaning new needle new bobbin thread upper thread..
did you clean the bottom bobbin area thoroughly? Remove the cover plate and bobbin reel, look for debris. Any left over cotton will cause problems, after you clean it spray some wd-40 on all moving parts.
Thanks
Adam
please leave me some feedback
Feb 18, 2011 | Juki TL-98Q
4th cotton reel keeps breaking
check the needle to see if it's damaged or has a burr
check the tension
change thread
check to see if the 4th reel is threaded correctly or if the thread get caught on something
Oct 21, 2010 | Janome Harmony 9102D Mechanical Sewing...
Top sewing thread keeps breaking
generally, this is a threading problem, but don't rule out that you may have a weak thread.
try cleaning all the guides by cutting a thread at the cotton reel and pulling it towrds the needle, and double check the tension. i hope this helps
Sep 07, 2010 | Janome 1600P-DB Mechanical Sewing Machine
My Husqvarna Designer I has an upper thread tension problem... the thread gets "caught" right at the beginning point of the threading process and the machine comes to a dead stop. There's major bobbin...
My guess is that it is the thread spooling off the reel that is the problem. Some of those specialty quilting cottons come on reels with plastic ends that have rough spots particularly knicks where you are supposed to "park" the thread end when you are done sewing. Run your fingers around the rim at each end of the reel and choose the smoother one to be the one closest to the threading mechanism. If neither end is suitable, flip the spool holder upwards so it is standing at a right angle to the machine, make sure the large spool holder is on then put the thread on - you won't need the smaller spool holder on top. Let the thread feed off from the right-hand side i.e. "under" the thread spool, across to the tension disks etc. Also be sure that the thread is not jumping out of that first thread tension slot.
Apr 26, 2010 | Husqvarna Designer I
Riccar 9600, no manual, how do we thread it?
If I remember it is reel of thread on the reel pin, make sure the presser foot is up and takeup lever at the top, take the thread to the left and over the top cotton guide, straight down through the tension disc and down to the larger guide, round the right and take the thread back up the left hand side, through the takeup lever right to left and follow the guides all the way down to the needle, thread needle front to back.
Mar 28, 2010 | Sewing Machines
Need Manual
I have one; please email me and I'll send you a copy of mine.
I'm also having a problem with mine; the top thread keeps breaking. I realize this must be a pretty basic question, but I am quite ignorant of the ways of sewing machines. I'm sewing just thin cotton pieces together for a quilt, Any suggestions would be welcomed.
Jan 09, 2007 | Husqvarna Husky 165
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
