Question about Yamaha RX-V559 Receiver
Receiver will not turn on Has no no way of signaling. Fuses correct replaced flip -flop TC4013 same situation as if no power
    Habit-Forming:
  • 75 Answers
Test current drain and then power supply out put
Posted on Dec 11, 2014
While assembling the seat we loosened the bolt to adjust the seat angle and the pipe fell into the bike frame.
Turn your bike upside down, it should fall out. If that doesn't work turn it upside down and tap on the frame that should make it come right out.
Apr 18, 2015 | Micargi RD 269 Fixed Gear Single Speed...
I have no low beam lights
Most likely the dimmer relay. Follow headlight wires back to a small box on usually inside passenger side fender. This should be what is called a flip flop relay. This relay receives a momentary pulse from the dimmer switch on the steering column. This relay may be located elsewhere. You may be able to google images for your vehicle and "dimmer relay" you may get lucky and find a picture of it and it's location and perhaps the wiring diagram.
Apr 14, 2015 | Saturn Vue Cars & Trucks
Hi, i have a 2004 pontiac vibe..overnite the head lights went out but the high beams work?? Checked fuses all look good???
Must be cold weather "eats" headlight dimming relay switch. Trace wires from headlamps to a small relay box. If it's a cold weather problem. I'd carefully try a hair dryer on it. See if it helps. If not, It needs to be changed. But it could also be a ground to the frame problem. Possible but not likely the wire from the Steering column dimming switch to the relay is a contact or wire break, or the switch itself. The dimming relay switch is a "flip flop" switch with momentary power or signal to the relay to change from low to high and back. If there is a problem in this signal wire or connection you may be able to jumper from the battery positive to the signal input wire momentarily to change from high to low.
Feb 28, 2015 | 2004 Pontiac Vibe
All 4 turn signals dont work
there should be a fuse for the direction light. and a direction switch can be bad and still click and operate as it suppose to
Dec 21, 2012 | 1997 Geo Metro
Car deck memory issue
Is the fuse blown on the memory wire from the decks wiring harness. Also, makes sure memory wire and accessory wire are not flip flop.
May 24, 2012 | JVC Car Audio & Video
Flip flop string torn from the base typical flip flop problem but they are only 1 year old.
The problem could be multiple things. One your feet may be too big for the shoes putting stress on the flip flop string, even though I doubt that it the problem, but a possibility. Two you may be over wearing them or in what is considered rough conditions, also usually not the case. Finally the shoes aren't made properly or well enough. Anyway with the first problem, you just need a bigger size. The second problem get shoes that can handle your everyday or also with the third problem you can repair the shoes. You can try to repair the shoes before they break or after. If they are cloth like then things like hot glue can be effective or using string like this website shows click here to see. If it is a rubber flip flop then you can also use glue or try what this website shows, just click here. Hope that helps.
Jun 04, 2011 | Havaianas Clothing Accessories
96 monte carlo rear window brake light works but not brake lights. tail lights work, blinkers work, replaced brake switch and bulbs still not working
This is a common GM specific problem. Your turn signal switch contains an elaborate networking device that has to cancel brakelights while running a turn light. Often times the ground within the turn signal switch is lost causing your situation. After investigating such other possibilities as fuses and loose grounds it may become necessary to replace the turn signal switch. Thank you, Dana
Sep 21, 2009 | 1998 Chevrolet Monte Carlo
Camera On Stand by
its hardware problem..go to service center
Aug 07, 2009 | Nokia 6288 Cellular Phone
Monitor not receiving signal from affected computer but works well with other PCs. 12/12/07-received a critical update from MS-after update installed correctly the situation became critical. The computer...
Basic network troubleshooting A network may not work because of any of the below reasons. ... card is not connected properly, or that the card is not receiving a signal from the network.
Good Luck...Please dont for get to Vote..Thank You.
Dec 14, 2007 | EliteGroup L7VMM2 Motherboard
Yamaha RX-V559 Receiver Logo
199 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
