Question about Dell Inspiron 531s Desktop Computer
Why is it my computer when it gets hot then my screen got some lines on the freeze.?
  • Dell Master
  • 4,201 Answers
May need to blow the dust out of the desktop get a can of compressed air and blow out the dust on the motherboard and inside the power supply unit. If it still freezing up check CPU fan is working and also you may need to put thermal paste under the cpu but that is a last resort. Check fans are working on power supply also.
Posted on Dec 11, 2014
Why does my washer’s water temperature change to cold when I close the lid and I have it set on hot.!
could it be that the hot line is plugged with dirt or frozen , check the screen in the hose end .Hot lines always freeze first
Jan 20, 2018 | Washing Machines
When I try to play my ps3 it will freeze up and show these red and green lines on my tv
This is a GPU chip problem, it has a bad connection to the motherboard, that can cause YLOD, no picture, freezing, pixilation, no hard drive activity, no synchronization with the controller through the USB cable , colors get missed up , see lines and different forms of pixels on the screen then it freezes, all these symptoms indicate a bad connection between the GPU chip and the motherboard, there is only one real solution , Reballing the GPU chip , PS3 GPU chip is a very sensitive chip due to the fact that it has a built in memory chips so you need a very reputable place to do that procedure for your console , the photo story you see is an example of the reason and the solution and the link is for the place to fix it for you and give you a one year warranty on the repair.
56c8f7ed-37a5-4044-aae4-c4667c5361b8.jpg 0080ee9a-6834-4bf3-aa92-040ee20db882.jpg PlayStation3 GPU Reballing service
Apr 21, 2014 | Sony Playstation 3 (PS3) Console
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
It will freeze up during a game
The freeze ups normally happen before the red lights of doom and they are caused by the GPU and the CPU getting too hot and the soldering snaps off so they lose connection.
If you stop the heat build up you will be fine.
You can do this yourself using a good repair guide or you can send it in and they will fix it for you.
Feb 04, 2010 | Microsoft Xbox 360 Console
Seems fine until I click play at main menu, then screen freezes with white lines going up and down screen.
Feb 02, 2010 | Microsoft Xbox 360 Console
Xbox 360 loading fault with dotted screen, checkered. freezes on loading screen even. sometimes it can appear there are several lines down the screen aswell so it may be 2 faults.
Jan 12, 2010 | Microsoft Xbox 360 Console
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Black screen freeze
You need to purchase a new hard drive because the one that you currently have is burned out. So go to a computer store and get a new hard drive and get windows installed on it and you should be just fine.
Jun 02, 2009 | Computers & Internet
Game screen freezes and there are white vertical lines on the tv
i dnt know about the vertical line but i had the same problemand i solved this by taking it to my nearest computer shop its as simple as that
Apr 14, 2009 | Microsoft Xbox 360 Console
Gateway laptop 450ROG freezes up after it gets hot & screen frzs
This definitely sounds like a heat problem. The system fan should cool it, but there may be a lot of dirt in the heat sink or along the path that the fan blows air. The first thing I would try is to get a can of canned air and blow it into all the vents under and on the side of the computer. If it is dusty, keep your face away.
You didn't say, but if you let the system cool down for a while (maybe 15 minutes or so) and start it up again and the same thing happens, it['s definitely a heat issue.
Feb 08, 2009 | Gateway 450ROG Notebook
Dell Inspiron 531s Desktop Computer   Logo
43 people viewed this question
Alun Cox
