Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
My Hotpoint SY36 oven has started making a clicking noise behind the control panel. The temperature light does not come on although the oven does heat up still.
  • Hotpoint Master
  • 744 Answers
If you have a problem with your hotpoint cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Posted on Apr 02, 2015
    Top Expert:
  • Hotpoint Master
  • 51,127 Answers
Call for a service man
Posted on Feb 19, 2015
jason0110
  • 66 Answers
SOURCE: hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Posted on Sep 14, 2007
  • 338 Answers
SOURCE: oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Posted on Dec 07, 2008
  • 4 Answers
SOURCE: hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Posted on Dec 27, 2008
  • 1891 Answers
SOURCE: hotpoint SY36 oven cuts out but fan keeps running
do you get code in display if so what is it . oven cutting out is a high temp problem probably / look for a thermo problem or sensor if digital . need a complete model # to help more if needed . hope this helped mm
Posted on Dec 04, 2009
sawdust46694
  • 398 Answers
SOURCE: hotpoint oven not heating up;broiler ok
the element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Posted on Jan 19, 2010
My hotpoint sy36 has power as the display / clock works but noting else will. no grill, no light, no fan and no oven. when i press the manual button it makes the little click/clunk noise that is should...
Does top burners work? If not, make sure you have 220vac to unit.
If it is the oven only that doesn't work, then it may be the temperture sensor, element, or control panel. You can take the sensor out and measure resistance across it with an ohmeter...at room temp should read about 2K ohms...in ice water should read less?in hot water more?...I may be backwards here, but temps should vary..(.must disconnect from connection to stove). Element disconnected should read zero or close end-end and infinite from end to outside.If these test ok, sorry but it's the control panel card....$300+ if not obsolete. New ranges are about $500+
Oct 16, 2013 | Hotpoint Ovens
Oven blowing cold air not heating up but grill is working
You need to replace the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Feb 01, 2011 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
No heat from cooker
If the fan is working o/k, then it is probably a faulty heater element.
This is located at the rear of the oven behind a removeable cover.
Please rate my solution.
Thankyou.
Feb 07, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint oven not heating up;broiler ok
Jan 19, 2010 | Hotpoint SY36 Style Line Stainless Steel...
2 of 4 ceramic rings do not respond to lowering the heat setting
You need 2 new temperature regulators fitting.
Quite a common problem..
Thanks
Plz rate solution
Dec 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven not heating
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint sy36 oven
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint electric cooker sy36
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
200 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
