I have a NP770Z7E-S01UB notebook. I can't get BIOS changes to stick so that I can boot from a CD.
Resetting the BIOS to boot from the DVD drive. Can't make the changes stick hence can't boot from CD.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
BIOS changes are usually saved using the F10 key or going to the EXIT menu and using SAVE & EXIT. This is detailed on page 99 of the User Guide which you can download from here:-
http://downloadcenter.samsung.com/content/UM/201408/20140828134026815/Win8_Manual_eng.pdf
If you use the Esc key to leave the BIOS, your changes will not e saved.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 11, 2014
  • 2,219 Answers
You don't change the BIOS, this is the basic setup the computer needs, it only needs to know the interface is there in hardware, the drivers are in the control panel which recognises the CD drive.
Support Laptops NP770Z7E Samsung PCs
To change the boot order from the BIOS SETUP screen you need to tell it that the CD/DVD drive is the one you want to boot from FIRST. Then you need to save the results, how you do this depends on the BIOS, but usually it is F10, to save the results before you exit the BIOS screen.
It will only boot from a CD/DVD if recognises a valid operating system on the disc, otherwise it will carry on to the next device looking for an operating system, usually the hard drive.
I have hp compaq 6730s before its got xp windows now the windows is corrupted now when I instal xp windows the system doesn't boot with external cd/dvd rom since the its own dvd rom doesn't work properly...
2008 PC from HP(old compaq name)
RECOVERY this PC ,per the book. (Ive done it)
this PC has a working F11 key if the HDD not bad, not changed out or the F11 partitions not damaged,
Power on hit F11 per the service manual. page 141
http://h10032.www1.hp.com/ctg/Manual/c01613452
CD boot fails
to boot to CD you must hit a key, called hit any key
to boot CD (aka. offically El Torito spec, wiki that and learn this)
If you dont hit (I use the huge space bar so easy to reach)
then no CD boots ever. by DESIGN. on new PCs that is true
and now you have to turn off SAFE BOOT too.
so those rules are first.
some PC, even make me hit (HP) the space bar to boot USB sticks this too is a fact. so do that.
my guess F11 is dead so you used discs, unstated disks , no HP disks (RIGHT>?)
XP the dead OS, this means adding things, , to the PC.
will fail. XP plug and play is dead, for vast things now for 3 long years, since MS ended this support. why not upgrade XP
to W7?
Old PCs do not like to boot , to external drives, its modern IDEA that (2008 is not too old,but IDK , if yours has it)
If you did boot to CD , inside or outside
XP (from MS ,not HP) will ask you to find drivers, and tell you to hit F6 and insert a floppy, tell me how you can get past here?
you cant, using NON HP install medial
XP is 2001 disks, 16 years old laying about. from MS
and guess what it cant see your HDD. due to no SATA drivers.
so the path you are on is full of pitfalls. see?
a modern feature in BIOS,its 100% a features of BIOS to boot any USB or External drive, (but eSATA might boot , not you no esata)
you posted with no mention of what external drive you have.
USB , esata, or what? Im guessing USB cable external drives.
the External drive needs a power pack to run right i most cases.
in bios, go to ALL screens, power on hammer F10
Setup bios is F10, go to all screens and turn on all USB features.
then change boot order to.
CD (hit space bar to boot CDs or DVD)
USB (hit space bar to boot USB devices (any key = space bar)
HDD.
then if all that above shows up F9 can be used to override above.
F9 only works if and only if.
1: bios supports it,! (IDK)
2: bios, has all USB features turned on, in other pages in BIOS.
including USB boot , turned on, if seen there. it must be on.
Enabled!
3: F9 only changes boot order this time, it does not enable features, that do not exist. ever.
why in the world not get a good CD/DRIVE. its like $10 used on ebay, pocket change, no?
or install with USB sticks?
there is legacy USB setting in BIOS, turn that on.
I can not teach you BIOS. (ive seen them all, so know this.)
but not yours, HP chances them like the weather, like the changing of the wind, directions. makers of BIOS changed 4 times!
and upgrades on BIOS changed on some HP PC, 10 times. or more. so I know NOTHING here, nor will most others due to that FACT. (unless theirs, is same as yours exactly)
only you can can explore BIOS, page by page and see what is there.
Test 1. (all techs have this in there KIT)
boot from USB stick, NOT external DVD drive)
if this fails doing DVD external boots is not possible.
find say any ISO for Unbuntu 17 linux, and burn the USB stick
using rufus. the boot the stick (fail now)?????????
that is the test for USB boot if that fails the PC is too old
and only fixing your bad DVD drive is the only cure.
Do not run XP with out SP3, once you have it running
XP has 700 exploits, and is a virus magnet.
never use XP is the best answer, but you you are not there yet.
so only BIOS matters now, that and only that NOW>
if the USB test 1 above works, I would.
id buy W7 from microsoft.com
the burn a stick
then load w7 , now it has future.
this PC is supported by HP in W7
here is the proof here
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-6730s-notebook-pc/3687778
never run XP or VISTA today, 2017, they are now officially dead.
Learn that booting is a function of BIOS not windows.
windows is a goal and is only startup files to load windows.
booting happens at the lowest levels ,in BIOS.
BIOS has code in my newer PC to boot to any USB device.
but not external drives.
tricks for compaq old
6730b the CD is called,
'Notebook Upgrade Bay'
(odd name that)
but I have a SDD in mine so not so odd !
trick 2, is some compaq change sata to IDE or the CD will not boot. (sad no?)_
BTW my HP laptop can boot to both bays, HDD and upgrade bay
both bays in mine are SDD. one is w10 other is Ununtu 17.
booting to external drives are the most difficult tasks of all
some do , some dont.
but I always start with a stick first. test that , for booting
then go wild with external drives. (booting )
this is all for now, we can peel the onion as deep as you want, ask.
Nov 25, 2017 | HP Compaq 6730s Notebook
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
Trying to start up in dvd rom
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. May be F10? In boot options make optical drive (CD\DVD) 1st. Save and reboot. You should get "Press any key to boot from CD".
Note: Some systems have an ad-hoc boot option during startup. Thus eliminating the need for BIOS change. Might be F12
Oct 12, 2012 | HP Pavilion dv9000z Notebook
How to install windows using a usb port? display says media not found.
You may need to go in to the bios and enable it to boot from a usb device.
Either a usb stick or a usb cd rom drive. You will need your Windows cd/dvd install disk.
You will also have to install windows on to a usb stick first. You can't just copy the files over to it as it has to be made bootable.
Use something like this.Wintoflash
Feb 06, 2012 | Toshiba Satellite A105-S4001 Laptop PC...
I have a laptop that there is no cd rom drive. my problem is i cannot install the operating system, it is windows xp service pack 3. please help me...
If you have no CD/broken CD on your laptop you have 2 options:
1) You can buy external CD/DVD writers that plug into a USB socket
That's the more expensive and simple option...and you'll be able to use CDs and DVDs afterwards.  You're looking at around $30-40.
2) The much more complictred but simple option is to get a USB stick, format it to be bootable with HP's formatting utility. Download and instructions here:
http://files.extremeoverclocking.com/file.php?f=197
Then you need to copy all the XP install files onto the USB stick; change the boot order in your BIOS to boot from USB before your hard disk (hit the F2 key repeatedly as soon as you've pressed the power on button, go to boot options and change the boot order.  BE VERY CAREFUL WHEN CHANGING BIOS SETTINGS!); put the stick in and restart.  With a bit of luck you'll be able to install from that.
Hope that helped.  Good luck!
Mar 10, 2010 | Dell Inspiron 6400 Notebook
How can i enable my Compaq presario 700 laptops booting fom externel cd drive
Go into BIOS and change the Boot Order, to Boot from DVD FIRST. This will then at boot time say Press any key to boot from CD/DVD.......
Feb 15, 2010 | Compaq Presario 700 470024-192 Notebook
How can i boot my IBM R50e? I put my cd in, restarted the computer but it starts windows normally. What do i do? I chose an option from the BIOS menu called usb cd, but still nothing happens.
Hi there.
Make sure the disk in the drive, go back into the BIOS menu, in boot options select CD/DVD drive as first boot device, press F10, save the changes and exit the BIOS.
The computer will restart and should boot from the CD.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | IBM ThinkPad R50e Notebook
Dell b130 upgrade to new hard drive trying to boot of from cd-rom but wont..... need help
did you change the order in the bios setinbg?put the 1st device for boot to be the CD/DVD-rom not HARD drive, to get into bios try F2., ESC, ,F12 . and in the bios setup change the order put 1st boot device to be CD/DVD-rom, then try again to setup Windows.
Mar 13, 2009 | Dell Inspiron B130 Notebook
I have a dell inspiron b 130 and my cd rom was pulled out by my son i wanted to know how can i boot my computer from the new cd dvd rom i need to format my laptop
you can configure it on the bios settings of the unit itself (possibly F2 or F11)
Then go to boot sequence then look for the removable device.
Then save your settings and restart your laptop. It should be working now.
Feb 26, 2009 | Dell Inspiron 8200 Notebook
I can't boot from external usb dvd/cd drive
please try to remove the connection between motherboard and vd/dvd drive.
then perform the previous steps.
Jan 27, 2009 | HP Compaq Evo Notebook N1020v PC Notebook
Computers & Internet Logo
124 people viewed this question
David Payne
David Payne
