THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
THE RECORD LOADS THE ARM GOES OVER BUT THEN JUST GLIDES OVER THE RECORD AND FINISHES.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 11, 2014
My Rockola 440 tone arm will not track a record. what might be the problem. Tried variuous tone arm weight selections.
One of the issues with that machine is cleaning the old lube out. IT gets thick and wont allow free motion of any of the parts.
Mar 26, 2018 | The Audio Players & Recorders
Have a Rockola Model 481. Arm swings over when record drops but as soon as it swings over to start position it resets.
There are a couple things that could do this...one would be if the reject bottom was stuck in or the wiring going to it shorted out, take an ohm meter and make sure there isn't a low resistance across it..The other thing I can think of is the reject switch on the tone arm is closed or out of adjustment and thinks the tone arm is at the end of the record so it rejects as soon as the needle sits down on the record
Nov 14, 2017 | Audio Players & Recorders
The tone arm drops onto the record, but then continues moving across the record without playing the record. Anyone know what's going on?
Does the needle actually contact the record? If not, you may be missing a "pad" under the record, or you may be simply missing the needle that needs to be there to follow the grooves.
Nov 02, 2014 | Audio Players & Recorders
My rockola 424 turns but wont play
Are all the gears at the base of the gripper arm free to travel their full distance?
Aug 20, 2014 | Audio Players & Recorders
Tone arm not lifting when record is over
Hello Caufield,
Ideas... Yes, indeed,
But without a MAKE or MODEL they focus
a lot on ESP & other psychic capabilities...
(Mind reading: The lack thereof)... Sorry...!!
In ye olden daze...
when I was young the (stacked record CHANGERS &
simple turn table) TONE arms were largely Rube
Goldberg
electro-mechanical thingy-ma-call-it...
that triggered off of the wag action of the center grooves ...
(in all 78, 45 and 33 rpm records (once upon a time)).
Rube Goldberg Wikipedia
Without BENEFIT of year, make or model... ONE
might ACTUALLY look at the mechanical MECHANISM
and SEE the broken or missing spring, link or cam...
The very first/last action of ARM CONTROL was
the lift/lay action of the tone arm..
Without that FUNCTION "working" you are just
ruining records & needles...
My best advice would be to REPOST with
a hint of the proper nomenclature... I'm pretty sure
an appropriate volunteer expert will step forward.
Try it... you will like it and it is still totally FREE
Carnac the Magnificent
Aug 07, 2017 | Audio Players & Recorders
The tone arm on my record player slides to the center of the record
usually there is sort of spring loaded screw situation under the tone arm
specifically for that purpose
Jan 30, 2012 | Audio Players & Recorders
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Problem playing 45 Records to their entirety.
There is an adjustment on the tone arm that you use to set where the tone arm picks up at the end of the record. This adjustment is normaly at the back (pivot point) of the tone arm and will be on the side probably. By the way, the tone arm is the part that the stylus is mounted to that swings back and forth to reach all the surface of the record. Make your adjustment and then test and continue doing this until you get it just where you want it. It is a process of trial and error. Good luck.
May 20, 2007 | Emerson NR303TT CD Shelf System
186 people viewed this question
 Grubhead
Grubhead
