Question about Sewing Machines
My Singer model 4610 jammed up and when I removed the metal plate the case was out of its slot. I could not get it back into the slot. Please help.
4 Suggested Answers
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 23 Answers
SOURCE: Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Posted on Feb 27, 2009
  • 1788 Answers
SOURCE: I have a 5050c singer The bobbin case jump out
I think that you have had the wrong size bobbin. It should be a class 66. Look in your manual, it should tell you. If, that is not it, call Singer at 1-800-4singer and ask if it sounds like the timing and if so where can you take it to get fixed. This is a nice machine, my friend, has one and it is worth getting fixed if you like it.
Posted on Jan 02, 2011
Testimonial: "it was in the timing .problem solved. thank you for your help. "
How to thread the bobbin of a singer 90s
First make sure that the needle is fully up (use the hand-wheel). Move the bobbin cover release button to the right and lift the bobbin cover out of the way. Remove the current bobbin, if needed. Hold the new, full bobbin so that the thread comes off the bobbin counter-clockwise when you pull the thread. Place the bobbin into the bobbin case. Pull the thread through the slot near the bottom of the case and to the left. Place a finger on top of the bobbin. Next bring the thread left further towards the back of the bobbin case until it stops in the second slot (near the 8 o'clock position if you compare the position to a 12-hour analog clock). Pull the thread back through the groove in the cover plate until it is cut by the thread cutter at the top left of the cover plate. (The thread will turn a "corner" to the cutter.) Replace the bobbin cover.
Singer has the manual for most of their sewing machines here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 90S is http://www.singerco.com/uploads/download/26e7243ab52aaed42904377fea7b090541eb0c9b.pdf . See pages 16-17 (page 18 in the PDF for the English description) and pictures that may be better than the verbal description.
I hope this helps.
Dec 23, 2016 | Singer Sewing Machines
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Bobbin
IMPORTANT: Always use a metal bobbin, or the magnetized bobbin case will not be able to function properly, resulting in a lack of tension on the bobbin thread.
9a8cb19.jpg Step 1:
Turn the handwheel counter-clockwise until the needle is in its highest position. Raise the presser foot lifter. Pull the slide plate forward and remove the empty bobbin.
Step 2:
Place the filled bobbin into the bobbin case, and pull about 4" of thread from the new bobbin. Make sure that the bobbin turns clockwise when the thread is pulled, or you will not have correct tension when you begin to sew.
Step 3:
Hold the needle thread loosely with your left hand. Turn the handwheel toward you, first lowering the needle, and continuing to turn the handwheel until the needle comes to its highest position.
Step 4:
Lightly pull up the needle thread and pick up the bobbin thread which will appear through the needle plate slot. Then pull both threads to the back of the machine leaving a 4" thread tail. Push slide plate back in.
Hope this helps. -samson39
Jul 22, 2009 | Singer Sewing Machines
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Bobbin Case
Jun 20, 2008 | Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
