Question about Sewing Machines
I can't get the bobbin case into its slot on my Singer 4610. When I tried it chipped a piece off. I don't know how it came out, I was already using the machine and sewing. The thread got tangled and the bobbin case was out of its slot when I removed the plate.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Simply try again smoothly and gently this time.
Posted on Dec 11, 2014
How to fix bobbin case in a singer 4610 sewing machine
go to this link and scroll down the page and you should see how you might be able to do it.. How to fix bobbin case in singer 4610 sewing machine Google Search
Oct 26, 2017 | Singer Sewing Machines
Singer 9420 bobbin case diagram
http://www.singerco.com/uploads/download/452_5_8_10_16_22_dial.pdf is the manual for the machine. The bobbin case is a single piece, and looks like: http://www.sewingpartsonline.com/bobbin-case-body-singer-383913-901.aspx?gclid=COqlw9-9yL4CFQqPfgodiC8A6g I don't know of a diagram of it.
Dec 22, 2013 | Necchi Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
Jun 09, 2012 | White Sewing Sewing Machines
My thread is bunching up and excessively stitching under fabric
What you have going on is probably a bobbin problem. The knots are referred to as birds' nests and happen usually happen when your bobbin thread gets caught on something in the bobbin area. To be certain it's a bobbin problem, change your needle. Even if the needle looks fine, it could be just slightly bent and still look fine to the naked eye. If that doesn't solve the problem, take the fabric out of the sewing machine and turn the machine wheel by hand. Watch what happens thru the plastic window in the bobbin area, or if you don't have a plastic window leave the bobbin covering off. Is the thread catching somewhere and causing a bunch of thread to gather in the bobbin area? Be very careful when investigating in the bobbin casing/area-it's easy to chip things in there! Often times, a piece of something falls in there and can be pulled out with tweezers. Just as often, the bobbin casing is slightly tilted and needs to be straightened or has a chip in it and needs to be replaced. You can normally get a replacement on eBay, searching with your machine model number. Also, check out SewVacUSA. If you need help replacing the bobbin casing (it's easy, you just need to be careful), or if these solutions don't work, leave me a comment. I check back daily, so I'll get back to you within 24 hours normally. Leave me as much detail as possible and I'll do everything I can to help you!
May 05, 2011 | Singer Sewing Machines
Model # 9113 - The thread bunches under the fabric but the top seam is okay.
My bobbin case came out of my sewing machine and I can't get it back in correctly. The bobbin case moves around. I have a singer cg-500/550
I just had this same problem and although i could not find the answer online, I managed to fix it.
If you look at the bobbin case there are 3 different tabs sticking out.
First you need to have tab #1 under the main part of the machine, and #3 over top of the small twisted metal piece below the bottom fabric gripper.
The hard part is to get the second tab into the proper spot. I circled the piece that you need to move in red. If you move the little piece by pushing it with a flat screw driver, you can line up the bobbin case so that tab #2 is under the metal piece and the bobbin case will be properly set.
Don't give up! It wasn't easy to get it back but I did it, I'm sure you can too!
Apr 27, 2011 | Singer CG754 Mechanical Sewing Machine
Singer 522. when ever I finish sewing a piece and pull the threads out to cut the bobbin thread always comes out of the case so that when I start up it makes a mess. I have tried tightening the tention...
Sounds like the bobbin case spring is failing to hold the thread firmly - especially if you've already tried to adjust the tension and it hasn't fixed the problem.
I'd suggest you replace the bobbin case, preferrably with a Singer genuine part.
Mar 27, 2011 | Sewing Machines
Bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Mar 17, 2009 | Singer Featherweight 132Q Mechanical...
Bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Feb 07, 2009 | Singer 6423 Sewing Machine
Bobbin case
If your machine is older than 18 months, it needs a free upgrade from your dealer. The plastic see through needle plate needs to be replaced by a newer version that will keep the bobbin down. Further more a bobbin case position finger needs to be installed.
Nov 06, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
