Question about LG 32LK330 TV
Lcd tv powers on but no video, blue light is on in the front and I can see the back light through the back but screen is dim
    Problem Solver:
  • 4 Answers
You have an issue with either capacitors or the inverter unit inside the TV. This is common with LCD monitors / TV's.
If you feel confident and competent enough, take apart the TV and check the capacitors on the power board. Some may look "blown" (bulging out at the top) and will need to be replace liked for like. Worst case it will need a new inverter which will cost around £20 at most.
I've fixed 100's with the same symptoms.
Posted on Dec 11, 2014
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Apr 30, 2017 | Televison & Video
Tv is dim and can't brighten
Apr 28, 2017 | Televison & Video
Bravia hdtv lcd momentary dim
It sounds like the power supply may be going. The back lights on a flat screen works the same as a flourescent light fixture. Flourescent lights have a ballast that powers on the bulbs. Flat screen tv's have capacitors on the power supply that when they charge power on the back lights of the tv. When you see the tv go dim it is actually the back lights that are dimming. This is usually from a faulty capacitor on the power supply not charging to its full potential. If you can open the tv and find the power supply look for any capacitors that are bugling at the top. These are most likely the culprits. A good cap tester is always handy to have although they are expensive ($100) it usually isn't cost effective to have it around just for rare occassions like this. You can remove the caps and take them to Radio Shack and they should be more than glad to test them for you. Before you do any of this though, look in your owners manual and see if there is a setting to where the tv does not use as much power. Maybe something like that is happening. The age of your tv can determine this too. If your tv is a few years old or burned for 20,000 to 50,000 hours the caps could very well be bad. Hope this helps. Good luck.
Mar 08, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
No picture
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
This is a power supply problem. Try to check the fuses ,fusable resistor ,capacitor and transistor in power supply board.
Hope it may help you;
Regards,
VOTIT
Oct 01, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Picture washed out, can't get it right
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
LG 32LK330 TV Logo
62 people viewed this question
Computer Repairing
Computer Repairing
