Question about Sansui Televison & Video
Sansui colour TV - sound is on but no picture - trying to fix via DVD player but not working
  • bronwen young
    bronwen young Dec 11, 2014
    Thank you but what can I do apart from taking it to a repair shop? Thanks.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Looks like the lcd panel is dead...
Posted on Dec 11, 2014
techman
  • 3130 Answers
SOURCE: No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Posted on Aug 02, 2006
SOURCE: sansui divx 9900 USB remote control code
dvd sunsui 9900 usb
Posted on Aug 04, 2008
weaponx69
  • 58 Answers
SOURCE: DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Posted on Jan 12, 2009
  • 7 Answers
SOURCE: I have sound but no picture
it does not support pictures
Posted on Jun 21, 2009
ravichetty
  • 158 Answers
SOURCE: dvd player no clour pictures only black white view
set the colour system to PAL
Posted on Jul 31, 2009
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
My techwood tv will not play sound and the colour is not right. how do I fix this?
see the charts troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
Try a direct connection from the DVD player to the TV set, instead of via other components.
Oct 14, 2013 | Gemini 1 Device Universal Television...
No sound on lg tv when connect dvd player through hdmi
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
Apr 13, 2013 | LG DVX583KH Player
Cant see dvd picture but can hear sound on tv
check the video jacks make sure it is properly fitted if it still don't work remove and plug the video jack again or clean the two end of the jack and the video jack slot on your tv and player or replace the jack. If it still don't work. try other dvd or the device has a problem.
Sep 12, 2009 | Sansui VRDVD4005 DVD Player/VCR
Blue picture
Be sure if you are using the 3 wire video (component input) that the green blue and red wires are connected correctly on DVD player and tv. If these are switched around or all three are not connected correctly you will get an off color picture. Do not confuse SINGLE WIRE (yellow composite video) with the 3 wire coponent or progressive scan inputs .
Aug 29, 2009 | Televison & Video
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
Ok,
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
