Question about HP Officejet Pro X576dw Network-Ready Wireless All-In-One Printer
My Hp office-jet Pro X576 printer is connected via a network and if l send a print job it displays printer error switch off machine and the printer restarts .if l use usd it works fine
Have tried to test it using usb and it works fine also have tried to connect it directly using Ethernet cable to my laptop the yellow and green lights on the RJ 45 jacks show that there is communication but there is no communication, have tried both the straight thru and crossover cable.
  • HP Master
  • 1,915 Answers
I would ensure that you have the current firmware installed on the printer and make sure that you are sending the job via network with a correct driver. If you manually set the IP address on your computer and the printer you should be able to connect direct using a crossover cable, I do that in the shop all the time.
Posted on Dec 12, 2014
adonscott
  • 106 Answers
SOURCE: Cannot print with wirelessly networked printer
hi,
if printing from 2 other computer works fine, will i think its not an issue of IP address which changes somehow. but anyways, try to check if you still have other printer drivers under "PRINTERS" (see control panel). it should say HP Photosmart c6100 series. If you also have there a printer icon that says HP Photosmart c6100 series Copy1, try using it (right click on that icon and choose Set as Default Printer). If you only have HP Photosmart c6100 series under PRINTERS, try to right click, then choose properties. When Properties box is open, click on PORTS tab. then click on configure ports below. Try to type in the IP address of the printer under "Printer Name or Host name or IP address". make sure that you already printed network configuration page to get the exact ip address of the printer, Dont know how to print? do this.
PRINTING NETWORK CONFIGURATION PAGE
1. press setup, then scroll down and look for Network.
2. press okay on network, it will give you the first option "VIew network settings".
3. press okay on it, and it will give you the first option "Print network configuration page."
4. choose that and press okay. it will print the network config page. from this document, you will be able to see the IP address of the printer.
Please let me know if the issue is still not resolve so that i can go ahead and give you another possible solution.
Thank you so much.
adonscott
Posted on Jul 07, 2008
kleeper
  • 87 Answers
SOURCE: Can I connect the printer directly to my laptop using ethernet cable
Hi! If the computer is connected to an HP All-in-One on a network, you can access the Embedded Web Server that resides in the HP All-in-One. The Embedded Web Server is a web-based user interface that provides some options not available on the HP All-in-One control panel, including advanced network security options. The Embedded Web Server also enables you to monitor status and order printer supplies. For information on how to use the features available in the Embedded Web Server, see the onscreen help within the Embedded Web Server. To access Embedded Web Server help, open the Embedded Web Server, then click the Help link under Other Links on the Embedded Web Server Home tab. NOTE: Only use the Embedded Web Server to change network settings if you cannot access the HP All-in-One control panel, or you need to change an advanced option not available on the control panel. Access the Embedded Web Server Use the following instructions to access the Embedded Web Server. You can only access the Embedded Web Server on a computer that is connected to an HP All-in-One on a network.
  1. Press Setup on the HP All-in-One.
  2. Press c00706174.gif until Network is highlighted, then press OK . The Network Menu displays.
  3. Select View Network Settings menu, then press OK .
  4. Select Print Network Configuration Page , then press OK . A configuration page prints, including the IP address. You will use the IP address in the next step.
  5. In the Address box in the Web browser on the computer, type the IP address of the HP All-in-One, as shown on the network configuration page. For example, http://192.168.1.101 . The Embedded Web Server Home page displays, showing information for the HP All-in-One. NOTE: If you are using a proxy server in your browser, you might need to disable it to access the Embedded Web Server.
  6. If you need to change the language displayed in the Embedded Web Server, do the following:
    1. Click the Settings tab.
    2. Click Select Language in the Settings navigation menu.
    3. In the Select Language list, click the appropriate language.
    4. Click Apply .
  7. Click the Home tab to access device and network information, or click the Networking tab to access more network information or to modify network information.
  8. Make any configuration changes.
  9. Close the Embedded Web Server.
Good Luck!
Posted on Oct 24, 2008
SOURCE: Cannot print on shared printer
I had the same problem with HP 1018 printer, when I had two computers connected to a domain and had Windows XP SP3 on them and when I shared the printer on one of them - I could only print from the network if the user belonged to the Local Administrators group on the host/server computer. Once the network user is removed from Administrators - the print jobs are stuck in print queue. I used the "HP LaserJet Host Based Print Driver Package" that is on HP web site for HP laserjet 1018 printer.
Then I tried to use a different driver for that printer and was successful with driver for HP LaserJet 1020. After forcing that printer to use the 1020 drivers, the regular users were able to print to that printer.
Posted on Jan 28, 2009
  • 1684 Answers
SOURCE: HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
  • 16 Answers
SOURCE: printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Posted on Aug 10, 2009
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Got my HP laser jet P1005 plugged into 1 PC prints fine. But 2nd PC is networked to it and it takes ages to print! How can I speed up send PC print job? Both PCs Only ever print single pages.
    Well, that really depends upon how you are "networked". Obviously, the primary PC is USB 2.0 connected direct to the printer. When you send a print job, the PC merely starts the print job and sends it to the printer on the fly. The other PC must first spool the entire job, packet it up, send it to the network, then network sends it to the first PC, where it must unpacket it, and send it to the printer. This is definitely going to be slower than a direct connection. And if your network connections are wireless rather than wired, even longer.
    Feb 19, 2016 | HP Office Equipment & Supplies
    Printer has always worked great, gets lots of office usage, but now suddenly won't feed; the machine will turn on, when the print queue is activated, but just "clicks", won't feed and the error...
    Try The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
    If you prefer, you can skip this information and go directly to downloading the tool .
    • Connectivity :
      • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
      • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
    • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
    • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
    • Device manager : Checks for problems in Device Manager that would prevent printing.
    • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
    • Port : Checks the port settings for the HP product.
    • Driver : Checks for alternate-driver settings.
    • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
    • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
    Oct 27, 2010 | HP LaserJet 1020 Printer
    My network thinks my HP office jet pro L7680 is only a scanner and is not recognizing it as a printer. Though I printed something yesterday. Then after I scanned something, it wouldn't print anymore. What...
    • Connectivity :
    Oct 26, 2010 | HP Officejet Pro L7680 All-In-One Printer
    HP L7780 error on printing.
    Uninstall completely all of the software that came with unit and then reinstall it.
    And HP customer service sucks - they will only help you out during the warranty period of their product.
    Mar 22, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
    My machine is hp officejet pro K850
    Sometimes when you unplug devices for 5 to 10 minutes the memory resets. This my help if not let me know.
    Dec 14, 2009 | HP OfficeJet Pro k550 Printer
    Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
    DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
    Oct 13, 2009 | HP LaserJet 4250n Printer
    Buddy
    Corporate Computer
    Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
    HP6110 All in one
    When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
    • Add paper to the HP Officejet series paper tray
    • Clear a possible print jam and proceed printing the fax.
    • Reduce the copying or faxing resolution via the front panel's menu.
    • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
    • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
    CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
    May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    HP Officejet Pro X576dw Network-Ready Wireless All-In-One Printer Logo
    129 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
