How to connect front panel - Computers & Internet
  • 27 Answers
Need more info...usually its connected the way you took it off...bottom edge usually goes in first then the back lip with the holes goes in the back once bottom slid in the base it usually slides forward allowing holes on the back lip to line up with holes on the case that holds the motherboard and then you can screw in the screws in all the holes :-P but again without more information than what you gave you might mean where to screw motherboard into the box and that again would require more details to receive the help you request in getting...good luck
Posted on Dec 11, 2014
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
I lost the connection's posisition of front power switch on my MS 7309, can you please send me a diagram of connections. thanks...
2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note: The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Thank you for using Fixya.
Aug 05, 2011 | Computers & Internet
Front panel audio
you cannot have linein connections from the front panel the motherboard usually dont support that.
IF you would like to have two lineins at the same time trty using a stereo splitter and a stereo extension cable.
Nov 10, 2009 | Computers & Internet
How can i connect front panel audio
You will need to install a extra hardware, a sound card with the internal extension using cable.
You will get extra cable with the sound card which will fit in front panel.
Nov 03, 2009 | Intel DG31PR Motherboard
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Front panel usb connection detail
To connect the front panel usb you have to open the cpu cabinet and on the motherboard you will find the usb pins where it will be written Front_USB you have to connect the front panel usb wires to these pins you should see that thier will be a no connection pin at one end which you have to plug carefully
May 09, 2009 | Computers & Internet
Usb front panel connection
it depends on weither the case and the motherboard are the same usb connection . make sure that there both usb 2.0 or 1.1 not one or the other as the connections or not compatible .
May 01, 2009 | ASUS P4SGX-MX Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Frontpanel sound
By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
Nov 18, 2007 | EliteGroup P4M800-M7 Motherboard
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
