Question about Cell Phones
I droped my phone the back came off along with batterie,sim card and the s.d. card..no mater what i do it says insert s.d. card.how do i fix it?
Just put it back together
  • 27 Answers
Turn it off take the SD card out turn it on turn it off put it back in turn it back on...make sure you are inserting the SD card correctly...if don't work take it to your phone provider and see what they suggest you might of broke the SD card during the fall or got oils on your fingers on the SD card and it may just need cleaned by your phone provider...good luck
Posted on Dec 11, 2014
Droped my boost mobile phone in toilet. My nephew dried out phone and removed sim card. I bent sim card a little inserting it back. Now im getting a no sim card alert. Do i need a new sim card.
If phone was on when dropped into water the electronics may have been damaged. Clean all sim card contacts and phone contacts and reinsert. If nada, it is damaged.
U might try another sim card to see if that works.
Nov 26, 2016 | Cell Phones
Install sim card
typically the SIM card slot is located under the battery. you would remove the back cover, then remove the battery. you should see place to insert the SIM card. it is usually identified by looking for a metal square about 3/4" H x 1/2" W and the plastic where the SIM card is inserted has an 'engraved' image of a SIM card and the correct orientation. without knowing the exact model, it is difficult to give exact information. another resource is to do a google or youtube search asking the question you posted along with the phone model number. hope this helps!
Mar 29, 2014 | Samsung Galaxy Cell Phones
Insert sim card
To insert simcard in your phone you need to take care of two things..one is the sim size and another is whether the phone is unlocked to accept all sim network.Regarding the sim size( the Samsung S3500 uses a Mini-Sim) try to get the desired sim size first.Check whether the phone is not locked with anyother different network.If so,it will not accept the sim that you enter.To unlock the phone visit Superunlockcodes.com and get the unique unlock code along with free unlock instructions.Once you satisfy the above conditions switch OFF the mobile and remove the back panel and battery you can find the sim slot below the battery...insert the sim in the desired position and replace battery and backpanel.
May 05, 2013 | Samsung S3500 Cell Phone
Sim card insert
To insert simcard in your phone you need to take care of two things..one is the sim size and another is whether the phone is unlocked to accept all sim network.Regarding the sim size( the Samsung S3500 uses a Mini-Sim) try to get the desired sim size first.Check whether the phone is not locked with any other different network.If so,it will not accept the sim that you enter.To unlock the phone visit Superunlockcodes.com and get the unique unlock code along with free unlock instructions.Once you satisfy the above conditions switch OFF the mobile and remove the back panel and battery you can find the sim slot below the battery...insert the sim in the desired position and replace battery and backpanel.
After droping my lg view it only says insert sim card? The sim card is in. How do I fix it?
the common mistake i used (happened to me)... i check if the SIM card is in the correct position, and if it doesnt work then hit the master reset key (refer to ur manual), and if it still doesnt work, then call LG and use ur warranty
Apr 08, 2010 | LG Vu CU920 Cellular Phone
Keeps saying 'please insert sim'
Your SIM card is not being read anymore due to a number of reasons.
Try rubbing the SIM card with a clean smooth dry cloth and then insert it again.
If that doesnt work, your SIM might be damaged, take it to your network provider and they will replace it, hopefully with your same phone number.
Nov 15, 2009 | Samsung SGH-J750 Cell Phone
Just got a i9 phone want to insert the sim card
it doesnt matter which one you use. if you place it on the far bottem and with the chip facing up that is sim card slot 2 if you use the top slot actually elevated off the board a bit with the chip down that is sim card slot 2. the only thing that matters is when you set up your phone it gives you the option of sim 1 OR 2. I use sim 1 and have my 2 disabled. it will tell you once its inserted which one you are in on the front display exampl it will say sim 1 t-mobile. go to i9forum.com for detailed on this phone.
Apr 06, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I dont know how to insert my sim card
Hey,
* Open ur cell phone cover(back)
* Remove battery.
* Insert sim in a jack(symbol 'll be given aside it, along with direction of sim).
* Put ur battery n cover back..
* Swith on ur phone..
Aug 22, 2008 | Cell Phones
Unable to use
Do a phone reset
try holding down the power
remove the back cover and battery
(at this point briefly let up on the power)
remove the sim card
wait for "insert sim card" message
remove battery
reinsert sim card and battery
release power key when the splash screen comes up
Feb 15, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Rejecting phone
You have to replace the SIM EMI Filter. It's a very small chip part near the sim connector. Replace it or clean it.
Feb 10, 2008 | Nokia 6230i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
