Question about Crafts & Hobbies
Lionel polar express cw80 just brought it out of the box for a 3rd year at Christmas time. The green light is on we can hear the quiet hum but the engine won't move. Cars don't light up either. Anyone have insight thanks!
5 Suggested Answers
SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Posted on Dec 08, 2008
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Posted on Dec 25, 2010
residentoccu
  • 161 Answers
SOURCE: lionel polar express train is stopping on the track, then becomes disabled
Replace all the batteries, then keep the remote close to the
train. if it's too far away, it will shut down.
Posted on Mar 02, 2013
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
The 3rd passenger car has short in it and causes green light on cw80 to blink. Checked wires and contacts on trucks can't find problem.
Lionel uses insulated wheels on there power pickup trucks , one side will have insulation bands and one will not , insulated bands need to be all same side on same truck , lead end is different than tail end this is how it picks up power from tracks , sometimes trucks axles get popped out in playing and maybe don't get popped back in the same way , also its possible for insulating bands to get holes in them from use , a dot or two of black latex paint fixes these up (don't paint entire wheel)
Dec 01, 2015 | Lionel The Polar Express Train Set
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Feb 10, 2015 | Lionel The Polar Express Train Set
Just setup our Christmas present the Lionel polar express set. It ran a few times and stopped and will not go. I have read everything I could find online and even trouble shooter setup and wires. I am
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating hours wondering why their train wouldn't move.
Dec 20, 2014 | Lionel The Polar Express Train Set
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Dec 28, 2013 | Lionel The Polar Express Train Set
Won't start
There are more than just one Polar Express set. What's the set number?
Dec 25, 2013 | Lionel The Polar Express Train Set
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Crafts & Hobbies Logo
46 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
