Question about Sewing Machines
What screwdriver to replace viking topaz 30 needle threader
  • 8 Answers
SOURCE: the needle threader has stopped working
Check you needle size. On my machine the needle threader does not work with the smaller needles, 9/65 and 11/75. The eye of the needle appears to be just short of the hook on the needle threader. I have no problems threading needles in larger sizes.
Good luck,
SewReady
Posted on Nov 12, 2008
  • 6 Answers
SOURCE: problem with automatic needle threader On Viking Designer 1 serie
Yes, I fix them all the time. You will need very good eye sight as the wire/metal hook is very small. If you get at an angle where you can see how the hook lines up between the metal flaps that hug the needle, the hook will probably be off center. You will need something very flat, but strong. I have use the exact-o-knife blade, in the handle of course, a knife, and a tiny screw driver. The hook has to line up vertically and horizontally. What usually happens is when we thread the needle it did not line up exactly, and putting pressure on the white tab, bends the hook. Bend it back and you are in business. If the threader does not line up horizontally, the needle threader may have slid down the shaft. This take a special tool. I purchased mine at Sears tools. There are 2 screws on the back of the threader. Move the needle to the highest position and after loosening the 2 screws, you can slide the threader up and down on the silver shaft, this is trickier, because the shaft moves up and down and rotates as it gets close to the needle. I use calipers/hemostats to hold the shaft while I line up the hook.
Hope this helps.
Posted on Jan 07, 2009
  • 152 Answers
SOURCE: I have a Husqvarna Mega Quilter Viking. The
If you're sure you're using the correct needles, you should take it to a service tech to align it properly.
Posted on Nov 02, 2009
  • 1116 Answers
SOURCE: AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
Posted on May 01, 2010
  • 14 Answers
SOURCE: all of a sudden, the needle threader won't work.
I don't know much about Brothers but the first thing I do with any new machine I get it to get rid of the needle threader if it is in my way. They never work and with use they start to shread the tread.
I use a bright light and a strong pair of glasses to hand thread it. I use tweasers on my more difficult machines.
You may have a lemon of a needle threader too. It happens. There are sharp barbs that we can not see but the thread has a hard time catching on them and most of the problem seems to be in the threader letting loose of the thread as it is caught on these barbs.
Posted on Dec 18, 2010
Needle threader won't work on my Singer 4423
The needle threader hook is very tiny and easily bent or damaged.
The needle threader is designed not to turn, if the needle is not at its most upper position to protect the threader - Turn hand wheel until needle reaches its highest position.
Needle not alining with threader hook - Replace needle.
Threader hook bent - Replace with new needle threader hook.
Hope this helps.
Read more from the link I attatched.
Good luck & have a nice day!
Automatic needle threader will not work
Jul 14, 2017 | Singer Sewing Machines
Needle threader doesn't move and stays in the low position. Husqvarna designer SE
This could be due to one or more causes.
1. The return spring has come loose.
2. The threader shaft is bent.
3. Lint on the threader shaft is preventing the shaft movement.
A trained Viking repair tech can determine the cause and take the appropriate corrective action.
Do not force the threader shaft up!!! If you can gently push the threader shaft up, but it will not stay up, the tape threader up and continue sewing until you can take to SE in for repair and servicing.
Feb 05, 2015 | Husqvarna Sewing Machines
What screw do you use to remover a needle threater in a viking topaz 30
I believe if it is not Philips cross head then either a torx or allenkey.
Dec 12, 2014 | Sewing Machines
How do i adjust the needle threader on a Phaff 1222E?
Bend by eye with tiny screwdriver...or replace, they do get bent
Feb 27, 2014 | Sewing Machines
Self threading
first make sure your needle is fully seated in the needle bar.
Jul 18, 2012 | Husqvarna Viking 1
How do you use a needle threader for a plus 1 viking sewing machine
If it's the viking needle threader that was made for this machine, you would mount the needle threader over the needle screw. The part that fits over the needle screw of the needle threader is an eccentric. You rotate it until the hook of the needle threader slips into the eye of the needle. Once that happens you mearly put the thread in front of the threader hook and pivot the needle threader back out of the needle.
Apr 26, 2011 | Husqvarna Sewing Machines
How do you align the needle threader on Husqvarna Quilt Designer II?
You need a torx #6 screw driver to loosen the screws on the back of the threader, (I use magnifying goggles to see the threader) then put the threader in the down postion and look to see and make sure the hook of the threader goes through the eye of the needle. Holding the threader in the down positon with the hook sticking through the eye of the needle, tighten the screws on the backside of the threader, Double check it (slowly) to be sure it didn't move while you tightened the screws.
Nov 06, 2009 | Husqvarna Viking 1
Nov 01, 2009 | Husqvarna Viking 1
Problem with automatic needle threader On Viking Designer 1 serie
Hope this helps.
Dec 24, 2008 | Husqvarna Viking 1
I need to replace the needle threader on a viking 750 sewing machine
I recommend that you take it to an authorized dealer and get it replaced. The threaders are not inexpensive and you can easily damage a brand new one while trying to install it.
Also, if the hook is still present but bent, a technician may be able to straighten it for you. With a new owner, I usually straighten it for the first year while the customer is learning to use it and then replace it at the 1 year anniversary when it is far less likely to get bent again.
Sep 03, 2008 | Husqvarna Viking 1
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
