Question about Life Fitness Lifefitness 9500 Treadmill Walking Belt
When i reset the main button tread work properly. but i stopped it shows again "waxer unplugged, maintenance required". In order to use it again i have to reset the main button. What should have been
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 24, 2013 | True 850 ZTX-P Treadmill - Serviced
What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    I recently purchased a Bowflex treadmill and while I was walking on it, it stopped working and shows the error message "Safe Out" on the console. The safety button is in place and I tried...
    hi,
    i think ur tread mills motor controlling circuit have some problem. may be its motor controlling igbt faulty. check it. proper care should be taken will working in tread mill. all the circuits are live . chances for electric shock. do any thing only after removing the power.
    ok
    Dec 26, 2010 | Bowflex Exercise & Fitness
    Our machine display show the following masage MOTOR CONTROLLER COMM DRD
    two possible issues
    one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before
    two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell
    if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them
    a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month
    contact glide for their non clogging wax to resolve this issue
    good luck
    Dec 26, 2010 | Life Fitness 95Ti Treadmill 95 Ti
    I have an EPIC treadmill that is about 3 years old and I use it regularly. (not sure the model number at the moment, as I cannot find the booklet) The other night about 2 minutes into my workout, it...
    You will need the model number in order to order the correct parts. Under the front cover there is a tech sheet. It will tell you the model number. The model numbers are usually on the frame, and can be found once the treadmill is folded up. Yours will be something like EPCL******.
    It sounds like you may need a motor controller PCB. The motor might be defective, but they generally don't just stop like yours has...
    The model number tag also has a phone number to call for service. They can send someone out to look at it if you require a technician..
    1-888-922-4222
    Dec 14, 2010 | Epic Exercise & Fitness
    Printer maintenance
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp190#ServiceAndSupport
    Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
    1. On the operator panel, press the <ON> button. (The display will go blank.)
      Note: It may be necessary to unplug the power cord if pressing the ON button does not shut off the printer.
    2. Wait approximately ten seconds and then press the <ON> button again.
    3. Wait until the device has completed its cycling process before submitting another job request.
      Note: It may be necessary to unplug the power cord and retry if the above steps do not clear the error.
    (This is for 2,113,0 error not 2,114,0 error which isn't listed.)
    Aug 03, 2010 | Canon PIXMA MP190 All-In-One InkJet...
    How to reset error e4
    The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
    Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
    1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
    2. Push Power switch then remove power cord.
    3. Insert plug power cord while pressing “power switch” at the same time.
    4. Push Start/reset by step 2 continue Wait display shown “0′
    5. Push + change display from “0′ to “1′
    6. Push color button 2 times
    7. Push Power switch again , Printer will print 1 page
    8. Open cover
    9. Unplug power cord
    10. Take out ink cartridge #40 and #41
    11. Insert plug again
    12. Push power switch
    13. Open cover (scan cover)
    14. Insert ink cartridge #40 and #41 again
    Enter to service mode for canon MPXXX
    • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
    • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
    Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    Apr 12, 2010 | Life Fitness 9100 Next Generation...
    Life Fitness Lifefitness 9500 Treadmill Walking Belt Logo
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Electro Med Services...
    Matt Olenzek
    Matt Olenzek
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
