Question about GPS
Garmin nuvi 65lmt wont turn on. Press the power button and it says "garmin" for 2 seconds then disapears and trys again. It's stuck in this mode. Tried a hard reset that did nothing still won't turn on. Tried linking it to a laptop.. it wouldn't even recognize the gps. So I'm basically stuck with a paperweight I paid 200.00 for. And yeah I'm beyond upset
  • 27 Answers
Have you tried replacing the power cord?
Posted on Dec 11, 2014
  • John Ellermann Jan 04, 2015
    I tried reseting it. Tried a different power cord and still nothing worked. I took it back and ordered a new one. 2 weeks of trying everything was pointless, I even contacted Garmin who told me the unit had a software problem and I should exchange it for a new one.
Sudbury
  • 18 Answers
SOURCE: garmin nuvi 5000 wont turn on.
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Posted on Aug 01, 2009
SOURCE: Garmin Nuvi stopped working and won't restart
Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
Posted on Aug 10, 2009
pabloloco
  • 2335 Answers
SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Posted on Jan 15, 2010
  • 7 Answers
SOURCE: Garmin Nuvi 255w freezes
mine would constantly cycle in the reboot. I had to clear the stored data by pressng and holding the lower right side of the screen and turning on the gps. once it boots up, it will ask if you want to clear the data memory (will not clear the actual maps). say yes, when it reboots, you will have to redo your personal settings as if it was new out of the box.
Posted on Mar 31, 2010
SOURCE: Garmin nuvi 1300 won't turn on!!!
we are having the same issue with ours - sometimes it will power up no issues and other times it the power button won't work - seems lots of this brand, different models all have the same issue - not sure what the solution is though
Posted on May 13, 2010
I would like to register my new Garmin nuvi 65 lmt and fin instruction manual
You register your GPS using the Garmin Express program from Garmin. Down load and install the program, then connect your GPS to your PC. The program will prompt you to register the GPS.
Instruction manual: https://support.garmin.com/support/manuals/manuals.htm?partNo=010-01211-60
Dec 14, 2016 | Garmin nuvi 65LMT 6.1" GPS with Lifetime...
Nuvi will not turn on
What model Garmin Nuvi ???....
On occasion, your Garmin GPS may experience technical malfunctions, including failing to power up.
When this happens, perform a manual hard reset of the unit.
A soft reset entails holding the power button until the unit powers down, and then pressing the it again to power the device back up.
However, when the unit won't turn on, a soft reset won't work. In this case, a hard reset is the only way to get the device up and running again.
Unplug power and USB cables to disconnect all sources of power to the unit.
Place your thumbnail into the groove located below the Garmin logo on the face of the unit.
Pry the faceplate off using gentle pressure.
Press the reset button and hold for approximately 3 seconds.
When the device is facing you, the reset button is located in the middle of the right-hand side of the front of the device.
Snap the faceplate back into place.
Press the power button.
Your GPS should now turn back on.
Garmin Nuvi With No Power
A Garmin Nuvi is a type of GPS device that can help you find your way around when traveling by motor vehicle.
You can mount the Garmin Nuvi inside the windshield of your vehicle and allow it to acquire the satellite signal.
This tells the device where you're located.
After that, you can find simple directions to get to a new location by entering the address into your Garmin Nuvi.
If you find that your Garmin Nuvi has limited or no power, you will need to do some troubleshooting to get it to work.
Change the fuse within your unit's power cable.
If your Garmin Nuvi has no power, the fuse may be out, meaning the device cannot be charged.
Plug your Garmin Nuvi into the power supply of your vehicle and turn the vehicle on.
The device cannot charge and get power unless the vehicle is running.
Allow the Garmin Nuvi to charge fully.
You might be unplugging it from the power source too soon, which could cause the device to have little or no power.
Regulate the temperature of your Garmin Nuvi.
It may not function properly if the temperature is too cold, below 32 degrees Fahrenheit, or too hot, above 113 degrees Fahrenheit.
Aug 10, 2013 | GPS
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
Garmin 265W After cleaning the screen with a duster--switched on, the screen will not respond to touch, I have updated software but cant use garmin as screen wont respond. cant hard reset again as screen...
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Aug 28, 2011 | Garmin Nuvi 265W GPS Receiver
When i turn the power on it just keeps flashing Garmin.
You can try three things to try and get the Nuvi to start normally:
1) soft reset: Press the power-on button for at least 20 seconds - starting from power off. It should restart.
2) master reset: This will revert to factory defaults erasing all POI's, Favourites, Tracks, Routes etc. From power-off hold the lower right corner for at least 20 seconds while pressing the power-on button once. A question should appear to erase all user data. Press yes and it will revert to factory defaults.
3) Connect a USB cable in power off. Connect it to a PC / Mac which is also powered down. Start the PC/MAC - the Garmin Nuvi should start in communication mode. Connect to the internet and load MyGarmin.com and try to update the software version to the latest one (if available). If necessary install the Garmin communication plug-in in the webbrowser.
Jul 10, 2011 | Garmin nuvi 1300 Car GPS Receiver
My Garmin nuvi 265W - when you turn it on is stuck on the loading maps page.. any suggestions
do this.,
1. get it connected to ur pc and see if it seeks any software update through garmin.com
2. if no updates needed, start again see what it does, if same stuck, while stucked in loading reset it by press and hold the tiny reset button for atleast 8secs and release , it should then come back to normal.
Pls let me know the result.
Thanks and regards
Jul 30, 2010 | Garmin Nuvi 265W GPS Receiver
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
Charged my new nuvi 760. Unit will not turn on. Followed the steps in manual, held the on button to the left for 8 seconds, then turned it on and nothing. If I plug it back into the wall charger the Garmin...
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Apr 28, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin nuvi 200 wont calibrate
I think I just solved this!
(I had the same problem.)
Hooray for google!
I found the answer here: http://www.gpsreview.net/forums/viewtopic.php?t=4999
"72 Troubleshooting - Screen:
If the touch screen is not responding to your taps properly, calibrate the screen.
Turn the Nuvi off. Then, slide and hold the Power button to the left for about 30 seconds."
After you slide, and hold, the power switch to the left (ON position) for 20-30 seconds, the next screen that comes up should be the calibration screen, telling you to press the dots on the crosshairs.
I recommend using your finger to press the dots, just as you would in your vehicle. I thought I could be more precise using a stylus when I first got the device, but apparently that is what caused the problem in the first place.
Live & Learn!
FWIW -- I have the Garmin Nuvi 200 (not 200W).
I don't know why this problem is listed under 76Cx.
Oct 09, 2007 | Garmin GPSMAP 76Cx GPS Receiver
GPS Logo
522 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
