Question about Dishwashers
The water does not heat up
Power works fine but water does not heat up
  • 35 Answers
Heating element needs to be replaced.
Posted on Dec 11, 2014
Maytag dishwasher MDB6160AWB "Clean" indicator
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Maytag Dishwasher
I have a kitchenaid dishwasher modl # KUDIO01IL. Someone opened the door during a wash cycle and now the CLEAN LED is flashing. Tried pushing cancel and unplugging. No change. Any ideas/
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The "clean" led flashes and
Hi
Daniel
Nov 26, 2010 | Kenmore Dishwashers
The clean light continues to flash and cannot clear. The unit has been noisier lately.
Hi
Daniel
Oct 26, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
"Clean" light is flashing and cancel button will not correct problem. Is there a way to reset so dishwasher can return to normal operation?
Hi
If clean light is blinking 7times then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Oct 23, 2010 | Dishwashers
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
After starting dishwasher to do a normal wash with heated dry, the dishwasher stops and Clean light blinks 7 times, pauses and this continues until I reset the machine. After reset it goes to rinse only...
Hi
If this doesn’t work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Daniel
Aug 20, 2010 | Whirlpool 24 in. DU1148XTP Built-in...
The "clean" light is blinking - so the dishwasher isn't working.
Hi
If this doesn’t work then it’s an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
Gas detector fuse keeps blowing as soon as the thermostat clicks for the heat to come on why. the water heater and stove work fine this happens when plugged up or running on battery power this is on the...
ANOTHER FACTORY BLUNDER. UR RV SERVICE TECH SHOULD HAVE CAUGHT THIS WHEN THEY SOLD THE TRAILER TO YOU. UR GOING TO HAVE TO FIND ANOTHER POWER SOURCE FOR THE LP DETECTOR. NORMALLY IT CONNECTS TO THE WATER PUMP WIRE OR THE HOT WIRE TO THE MONITOR PANEL.
Oct 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
