Question about Kenwood Car Audio & Video
No audio on a Kenwood TS-950SD ham radio after clipping D-17 to allow MARS operation. Sound is weak at headphone and ext speaker jack with volume control almost full up.
Checked all cabling into and out of DSP unit and all are good. Already done the factory reset. Can not find any broken wires and have pulled and reseated almost every cable in this radio. Still no sound to internal speaker which had plenty of volume at # 2 setting out of 10 on volume control before the D-17 diode was clipped to allow MARS operation. Already reconnected D-17 and still no audio. Any tips or ideas greatly appreciated.
sgregg
  • 133 Answers
SOURCE: Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Posted on Jul 30, 2007
  • 10 Answers
SOURCE: Aux input problem
Here's the link for the manual: http://vault.alpine-usa.com/products/documents/OM%20CRA-1667RF.pdf
Posted on Aug 20, 2007
Benimur
  • 6966 Answers
SOURCE: Fade F to R not working on Sony CDXF7000
Hi, To my knowledge, this head unit (Sony CDXF7000) uses individual 52 watts amplifier (X 4) whose output to the speakers require that none of the speaker wires be grounded or crossed/shorted. Please check the speaker wiring with the use of an ohmmeter (or a multi tester) with all the speakers temporarily disconnected. Verify that none of the 8 wires reads 0 ohms to body/chassis ground or to any of the other wires. As you have checked the wires area: front left > + red & - white/black stripe; front right> + gray & - gray/black stripe; rear left > + green & - green/black stripe; rear right > + purple & - purple/black stripe. Rewire should it be necessary. If the wiring fully checks out, it may be that you have a fader component failure inside the unit (though honestly rare). You can also check if there is no bridging modifications done; converting your 4 amp-4 speakers original design to a bridged 4X52=2X100watt amp to 4 speakers paralleled to 2. Another area you can check/try is by varying the DSO settings - 1,2,3,off. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Posted on Sep 30, 2007
Buffalo12980
  • 625 Answers
SOURCE: wiring-audio system-1989 ford crown victoria
go to an autozone or advance auto parts store and find a haynes auto manual for your car. electrical diagrams are in back of the manual.
Posted on Dec 07, 2007
Sunil Panem
  • 80 Answers
SOURCE: No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Posted on Jan 30, 2008
KENWOOD TS 450S WITH RX PROBLEM
If you are still seeing meter deflection in received signals, it sounds like something in the audio amplifier went south.
Apr 23, 2014 | Radio Communications
No sound from internal speakers after using headphones
The headphone jack has a switch in it to disable the speakers when the headphones are plugged in. This switch has stopped functionong. Look in the jack eith a magnafying glass to see if there may be lint or some other object holding the switch open when the headphones are not plugged in. Otherwise it's time to replace the jack.
Apr 19, 2014 | HP (153147-001) Sound Card
Kenwood ka 127 volume
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 04, 2012 | Audio Players & Recorders
Mod BC100xlt --scannes,no sound ,tried squlch&volume no luck JERRY
Hello Jerry,
If you have an external speaker or headphones, plug it into the headphone Jack. If you get audio then your problem may be a bad speaker or a problem with the headphone jack. If you still don't get any audio then threre may be a problem with the Volume pot or Audio chip, in which case the scanner will require sevicing by a qualified technician.
Jul 21, 2011 | Uniden BC60XLT Handheld Scanner
Where to hook up headphone jacks to allow TV speakers to continue working while using headphones I.E. I have jacks on front of TV but they do not give me out put sound. which ones should I use on back of...
Unless you have an external headphone amplifier, you need to use the headphone jack socket, if there is one. Some newer TV's allow for separate headphone volume and speaker volume control.
Have a look in your user manual.
Jan 08, 2011 | Panasonic CT-36D20 36" TV
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
Sound volume
have you tried a different set of speakers? you should be able to plug them into the headphone jack. speakers without a power supply are softer. my laptops the same way. i use vlc player when i play videos because you can turn the volume up to 200%.
Nov 16, 2008 | Computers & Internet
Very low volume
check the mode button and make sure you are in the right mode, sounds like you have it in the wrong mode.
Sep 16, 2008 | Icom IC-R10 Handheld Scanner
Car Audio & Video Logo
43 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
