I have a LG Plasma model 42pg20, it was working fine but I moved homes. when I plugged it in the blue light flickered off& on, now blue light is on but no picture or sound.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Try doing a full setup and auto channel search because you may be on a different cable provider system in the new location.
Posted on Dec 11, 2014
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
  • 362 Answers
SOURCE: No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Posted on Jan 29, 2009
  • 20 Answers
SOURCE: 42 LG Plasma picture distorted and flickering
replace the control module.
Posted on Mar 11, 2009
  • 188 Answers
SOURCE: Lg 42pg20 Plasma Will not turn on
If there is no LED burning to indicate there is power than the power supply is faulty.Repair is not verry easy to do with these complicated power supply's.
Posted on Nov 02, 2009
taran_2005
  • 10515 Answers
SOURCE: LG plasma tv no sound no picture,green light on
You could try to unplug the TV for few minutes, say 30 minutes and then turn it on. If the same problem would still be there, it would confirm an internal fault. If the TV is under warranty, you could get it replaced or repaired unless you need to get it repaired. Obviously,you could call a tech on site to diagnose and fix the problem. If you have experience in electronics, could read schematics, would be able to use multimeter and could keep precautions, revert and i would be able to guide you.I would be able to send you a link where you could purchase a cost effective service manual that is needed to get this fixed.
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 09, 2010
Lg 42PG20 possible to work on a 220 volts?
The correct answer is "it depends on the power supply board used in it".
If you click on the picture at
http://www.coppelltvrepair.com/p/716/lg-42pg20-ua-power-supply-board-repair-service
and look at the lower left corner of the board you will see
100v-240V
printed in the lower left corner.
That board used in 42PG20 will definitely work on 220V.
Your TV may have a different board inside though.
DO not assume...verify.
Hope this helps!
Jun 29, 2014 | LG 42PG20 42 in. Plasma HDTV
LG 42" Plasma - remote wouldn't turn off TV, nor
unplug for a couple of hours. the tv holds charge and bleeds off electricity very slowly.
Mar 22, 2011 | LG 42PG20 42 in. Plasma HDTV
LG 42PG20 42" Plasma.
i have seen on some of those models bad power supplies. if you take the back off the tv you wil see a board in the top center that is the power supply board. you may have about 8-9 vented capacitors towards the left hand side of the board. they will look like they are exploding on the top some may even have black residue on the top that is the leaking electrolytic fluid. they will proabaly be 3300micro farad at 16volt high temp 105degree capacitors.
Jan 18, 2011 | LG 42PG20 42 in. Plasma HDTV
I have a LG42PG20 plasma tv that the sound works, but the tv has no picture. The screen is blank, dark in color.
cleanning inside,,,,check the red wire that to the screen inside moved it around,,,,plug in,,,try on...works....or not.so on..broken....not around shocks
Aug 27, 2010 | LG 42PG20 42 in. Plasma HDTV
42PG20 42 in. HDTV Plasma TV: i have an lg plasma tv - 42pg20 when i turn o...
There are several known issues that can cause that.
The top candidate is the main board, the next is the Y-Main board.
Here's a link for repairing the power supply board of LG 42PG20, which also contains a link to how to test your own board to see if it is good or not:
Hope this helps!
May 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Nov 02, 2009 | LG 42PG20 42 in. Plasma HDTV
Audio sync issues between my stereo and my new LG 42PG20.
i have samsung home cinema and a lg 42lc2d.
the samsung has 6 speakers but all i can get to work 1 front speaker.
when i trythe speakers on test mode they all work with the test sound
could you please help me
best regards ron mcneill
Dec 25, 2008 | LG 42PG20 42 in. Plasma HDTV
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
