Question about Kitchen Ranges
I have a problem with our stove we replaced the fuse cause we thought our front left element heated very low and it still did not work the element still heats low
Weve tried new fuses and element
  • 3,506 Answers
Yes if it heats at all it would not be a fuse.You do not advise the vintage or make and model so it is hard to advise. It could be the element control or the element that is bad/defective.
Posted on Dec 11, 2014
We have a JennAire model CP220W-C01 cooktop. We use the old coil type heating elements. There was a flash and smoke from the right front element. A repairperson replaced the connector, only to have it blow...
Unplug the element from the receptacle and then disconnect the receptacle from the point where it plugs into the stove. Now, carefully, turn on power to this heating element. If nothing happens then you have removed the likelihood of a problem in the large portion of the stove's wiring. Next, plug the receptacle cable back into the stove without connecting the heating element. Again, carefully turn on the power to the heating element in question. If there is no spark then the cable, connector and receptacle are ok. If it does spark, replace the receptacle and cable assembly. No spark, then inspect the heating element where it connects to the receptacle. Look for melting or signs of damaged insulation that would allow for a "dead short". If you see damage to the element then replace the element. No damage, clean the connections with a toothbrush, and plug the element back in and turn on the juice. If it sparks again, replace the element. Good luck and be careful. Don't attempt any of this if you are inexperienced in working with electricity. 220 Volts can cause death or serious injury... just the flash from an arc can cause blindness and burns.
Nov 05, 2013 | Jenn-Air Cooktops
The stove is 26 years old. Has been working very well. Now the two heating elements on the left side of the stove and oven are not working. The pilot lights come on. Fuses in good shape and 220 volts...
check the contact points on the rear of the element they burn off after years of use, if the contacts are still good, Look at the element itself for any white marks on the element, if you see any , the element itself has probably burned out and need replacing , to get to the contacts,, depending on the oven, remove the back they should be right in sight , if you do need to replace the fittings on the wire ends, be sure and get heat range connectors
May 29, 2011 | Ovens
Left front plate dead. Cant seem to find the fuses
there are no fuses on the unit it self -- the stove is protected by the circuit breaker at your main fuse box. if your front plate is not heating up I would say that you need a new heating element.
c...
Dec 31, 2010 | Ovens
The right front element will not heat properly on my Frigidaire electric stove. If you turn the knob to a low number it barely heats. It is very frustrating because you cannot keep something warm or cook...
Without a proper model number I would say you need to replace the element or the infinite switch for the element. Best off to call a reliable repair company such as Sears.
Jan 31, 2010 | Frigidaire Kitchen Ranges
Hi, I cannot get the oven element or the back left burner to heat up.I found a blown 15 amp fuse blown in the oven and replaced it but still no power to the two elements. I took out the oven element to...
I take it when you mention burners you are refering to electrical hot plates?
If you have tested with 110V --even nthough it should be 240V then I can assume that the hob is working.
Possible cause is the regulator.
Regards
Aardvark Repairs
Nov 16, 2009 | GE Ovens
Oven does not get warm, suspect it is a fuses but cant locate it
It is probably due to a broken heating element in the oven. These are relatively easy to replace. You can test it with an ohmmeter. It should measure low ohms. If it is open circuit then it is broken.
Jul 25, 2009 | Stoves 1100DFSID Kitchen Range
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kenmore electric stove model c880.6383880 left front burner does not work....it is not the element itself as it heats up on another burner.
hi,
sounds like you have the old-style coil elements on you stove.
your problem is the switch under the element, called the infinite switch. i would suggest to have a technician replace it. they usually charge for the labour but if you have never done it before, it's money well spent.
Aug 19, 2008 | Stoves Kitchen Ranges
Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | KitchenAid KERC507 Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
