About the C2300 error code you says that check the suction fan. please give the position address in machine
Guide us to fix myself there no engineer to know about this.
  • 3,506 Answers
Try www.printcopy.info/?l=en&mod=free&chap...code=C2300
Posted on Dec 11, 2014
checkitright
  • 1362 Answers
SOURCE: error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Posted on Dec 26, 2008
SOURCE: Kyocera Mita KM 1505 copier machine
Hello Sir,
I would like to ask you that I have a kyocera mita copier KM1505 and displays the code error like C610,So try to help me in order to resolve or fixe that problem.
Thanks
Pascal NIYONSENGA
Rwanda-KIGALI
Posted on Oct 12, 2009
  • 1297 Answers
SOURCE: Kyocera KM-C3225 error c2300
Check the suction fan.
Posted on Nov 10, 2009
firecontrol7
  • 6696 Answers
SOURCE: Getting Machine Error E04-14
Recommended you take it out and blow fan with can air. If the fan is good then you will need to replace the circuit board:( mite order a new fan first and connected then you will know if you have to order the board unless you fill confident to locate the main board and then locate the connector on it. unless some one has unpluged the connector doubt it is lose or bent pin inside it. Best to ask for a pansonic servive provider.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 21, 2010
randula7
  • 78 Answers
SOURCE: Kyocera KM-C4035E Colour Printer Copier. Help with
Fuser Motor Error. The motor speed is not stabile for 2 sec or more. Detection begins 1 sec after motor drive ON signal is output.
1) Run sim U030 (fixing motor) to check for drive problems,
2) Reseat YC27 @ engine PWB and motor connector,
3) Run sim U030. Check YC27-A10 @ engine PWB for a low output. If yes, repl fixing motor,
4) If no, repl engine PWB.
Posted on Apr 18, 2010
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
/uploads/images/copystar-c2300-error-code-34884244-4-1.jpg
Dec 11, 2014 | Copystar Office Equipment & Supplies
Copystar C2300 problem ?
fuser motor lock. bad fuser or exit turnover assembly not rotating properly. the duplex unit could also bind causing this. run u030 in service mode to check the motor.
Mercedes clk55 engine suction fan stays on as soon as the key is turned on.The black and white wire on the fan has continous positive,when I remove relay P in the front fuse box (terminal 15) the fan
The fan control module is defective.....would scan codes in engine control module to insure this diagnosis is accurate. I've replaced quite a few on Mercedes Benz models. The reason for the scan of the engine control module is to insure the DME (engine control module is not commanding "ON" the engine cooling fan. The factory scan tool can view these commands. If the DME is not commanding the suction fan to operate...the fan module is indeed defective.
Scott, Porsche Master Tech 35 years.
Jan 12, 2014 | Cars & Trucks
How to solve error code c2351 in konica-minolta bizhub 164
Suction Fan motor failure fan located right side of machine from the front. Check vent can air and remove cover check fan and or replace worse case the board
Apr 30, 2013 | Konica Minolta bizhub Office Equipment &...
I have konica Minolta bizhub pro c500 when i power on this machine the lcd shows massage sc41-03 please assist. Thank You Very Much
The 41-04 is a failed cyan write unit, or a failed suction/ exhaust fan. You can test fans m43,m44,m45,m46. In 47 mode, code 42, multi code 6.
Good luck
Jun 15, 2012 | Konica Minolta Bizhub Pro C500
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Kyocera KM-C4035E Colour Printer Copier. Help with system error code C2300
Feb 24, 2010 | Kyocera KM-1505 Copier
Muratec MFX1500 - "please call service" message
You probably have a faulty heater lamp or thermostat or thermistor on the exit side of the machine, and so it is not warming up and so giving you the error. check if it is warming up inside the machine where it says hot, but be careful just in case it is really hot( it should be above 100degrees celcius over there). You will need parts for sure.
Mar 18, 2009 | Muratec MFX-1500E Plain Paper Laser Fax
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
60 people viewed this question
k24674
jasbo
jasbo
