Question about Copystar Office Equipment & Supplies
Copystar C2300 problem ?
When i star the machine appear the C2300 error code, guide us to fix the machine. If it's possible give the position address on the machine, because in Aghanistan - Mazar province there is no engineer to bout this code. Many time i called to your branch in Kabul but they don't answer me.
  • Copystar Expert
  • 337 Answers
Fuser motor lock. bad fuser or exit turnover assembly not rotating properly. the duplex unit could also bind causing this. run u030 in service mode to check the motor.
Posted on Jan 08, 2015
jtuminaro
  • 56 Answers
SOURCE: machine error. no error code.
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Posted on Jan 15, 2009
  • 56 Answers
SOURCE: IP address for Copystar CS-3035
1.On the drivers CD You must have Quick Config tool.Just click on setup Icon and follow directions.
2.Or just press "printer"Button on the operation panel of machine.Go to Interface-TCP/IP and You will see IP adress.
You can also from printer menu select "print Status Page" and page will be printed.You can find IP adress on the status page.
Posted on Nov 28, 2007
maklean
  • 1665 Answers
SOURCE: C710 Code on Copystar 2030
Did you disconnect telephone line?
C710 : Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Posted on Feb 20, 2008
leroyal
  • 2120 Answers
SOURCE: Copystar/Kyocera 1620 error code: C-6 000
The fuser needs to be reset.
Posted on Mar 04, 2009
  • 215 Answers
SOURCE: copystar cs-2550 service code c6000
try this. enter "10871087" from keypad. you should now be in maintenance mode. enter "163"press "start or print" key. you should see a screen that says "execute" or it may say "reset". cursor or highlight "execute" and press "start" key. now press "stop/clear" once or twice. then press "01" then "start" to exit maint. mode. very important!! as soon as you press "01" and you see "please wait" open your front door. wait 2 secs, then close door. that should get you going unless there is a true failure. good luck and you may want to write this procedure down as it may happen sometime again.
hth,
razors
Posted on Mar 30, 2009
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
/uploads/images/copystar-c2300-error-code-34884244-4-1.jpg
Dec 11, 2014 | Copystar Office Equipment & Supplies
Error Code E07
  • Open the drawer the printer is currently pulling from when the error message "E07" appears on the display. Verify that the paper in the drawer is the correct size and close the drawer firmly!
  • Oct 23, 2014 | Copystar CS-1500 Copier
    CS-1820 Send function not working. Error Occurred; Results "NG"
    Upgrade the firmware and the diver software, that will help you to fix the problem.
    Jul 20, 2010 | Kyocera Copystar CS-1820 Black and White...
    I have a brand new Copystar CS-3060 turn it on and a ERROR CODE 3100 appears on the screen what does this code mean please??????
    The scanner is locked...look for some large yellow screws on the side of the machine or on the rear of the machine inside of a detent. Turn it left until it pops out to release the scanner.
    Mar 11, 2010 | Kyocera CopyStar CS-3060 Black and White...
    Error c-6 keeps appearing
    codes that start with c6 are caused by a problem in the heater. blown thermal fuse,
    or bad heater lamp. you can access from the rear of the machine
    Jul 15, 2009 | Copystar CS-1500 Copier
    I'm getting c-6 400 code
    This is a fixing error.But it can be caused by a power dip aswell.
    Try to reset it,if the error presist then there is a problem on the fixing.
    To reset-Switch the machine off,open the front cover,switch the machine on again.If it shows "open cover",press the system menu counter button.press the arrow up ones to display system settings,hold the start and # button in and press "ok"or"set"
    go down with the arrows untill maintenance mode is display,press ok,then enter the number 163 and press ok.
    set it for exeuteand press ok.
    Then the error will be cleared.
    Jan 22, 2009 | Copystar CS-1500 Copier
    Error Code 2102
    Change the SMTP port from 25 to 587
    Oct 21, 2008 | Kyocera Copystar CS-1820 Black and White...
    Copystar 2014 UF error code need help
    Take Out Toner Cartridge. Looking straight through there should be a tiny switch that tells the machine there is a toner cartridge present. It might have just gotten out of position or may be broken, which means you'll have to replace it!
    Aug 19, 2008 | Office Equipment & Supplies
    Copystar CS-1810 Error Code
    I'm sorry, Copystar is not a brand I am familiar with.
    Be blessed.
    Mar 19, 2008 | Copystar CS-1810 Copier
    65 people viewed this question
    Top Copystar Office Equipment & Supplies Experts
    Kyocera HP Expert
    CheckitRight
    CheckitRight
    Tammie Duggan
    Tammie Duggan
    Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
