Question about Garden
How do i fix a 3 point hydraulic system on a bolens iseki g194 tractor?
3 point stuck in up position weight did not work
  • 2,760 Answers
If it's possible that cylinders are rusted or bent , with engine off you;ll need to loosen , both hydraulic lines from cylinder , use a pry bar to pry down , if it still wont move your gonna have to pull both pins from ends of cylinder and replace cylinder , a company in wisconsen makes any cylinder you'd ever need
Posted on Jan 06, 2015
4 Suggested Answers
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
  • 21 Answers
SOURCE: the 3 point linkage on a ford 4000 tractor is only lifting half way and stopping with weight on it. what would be the problem?
I am not an expert nor have much experience - just a guess - low on hydraulic fluid? Check hydraulic fluid reservoir, if any, for correct level of fluid. Add correct fluid if necessary. If really low - suggests a possible leak somewhere. Should check for that as well.
Posted on Dec 06, 2011
  • 6468 Answers
SOURCE: hydraulic 3 point hitch is stuck in the up position
check the linkage on the valve
Posted on Aug 16, 2012
Where is the breather for the gearbox
On the higher position of the gearbox.
Jul 08, 2017 | Garden
Changed hydraulic filters now hydraulics don't work?
Sometimes with hydraulics you need to "burp" any air from the system, though they tend to be so-called self bleeding. Try filling the filter with fluid and check that the pump has fluid in it to get it pumping. If the fluid was drained from the pump and it has air in it, it won't do anything. Get some fluid in it and it may start pumping.
Apr 04, 2017 | Garden
Hydrostatic transmission fluid needed for bowlens tractor
The Bolens or iseki G152 will take a "TDH" fluid. The local Tractor supplier told me that as long as it says "Transmission / Hydraulic" on the container I would be OK. Most of the newer (and some older, like ours) have a single sump for the Hydraulics, differential, and Transmission and this is the product most of them use. I've been putting that in on my G152 (tx1502).
Any local tractor supply will have it. Even NAPA auto parts carries a TDH fluid. Again, whatever brand you get make sure it says "transmission / hydraulic" on the label.
Flyer
May 26, 2016 | Garden
Were does the wire for the points on a bolens 1058 cone from
The ignition coil will have two small nuts , one on each side of the spark plug wire. It can be labeled many ways, + - , pos neg , Bat Dist , point will hook to the - ,NEG , Dist . The only time this will be the other way is when you system is a Positive ground, that is the + , positive of the battery hooked to the frame instead of the - Neg.
Mar 13, 2016 | Garden
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
Hydraulic 3 point hitch is stuck in the up position
Aug 15, 2012 | Garden
I have a 4310. The three point lifts only under high rpm and won't lift any weight at all. Cleaned screen and replaced suction and trans filters. Still have problem.
A 4310s 3-pt should be able to lift approx. 1-ton at 24inches on the 3-pt lifting arm. I thought there was a hydraulic reservoir and a transmission reservoir and it is not uncommon to put the wrong fluid in one of those You might check that transmission fluid didn't get in the hydraulic tank.
May 16, 2012 | John Deere Seat 4210 4310 4410 4510 4610...
The 3 point linkage on a ford 4000 tractor is only lifting half way and stopping with weight on it. what would be the problem?
Dec 06, 2011 | Garden
Bolens garden tractor will not start
At this age, the engine will have points under the flywheel. If the coil is OUTSIDE the flywheel, forget fixing it and just replace the coil with a later solid state unit, then cut the points wire.
If the coil is UNDER the flywheel with the points, you'll have to stick with them, but replace them AND the condenser. These parts (and replacement coils) are still available, but decide quickly - Tecumseh have gone, and when all these old parts are used up, that's it.
May 08, 2010 | Garden
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
