Question about Garden
Do you have a manual for a LELY 4 disc mower
How to set up mower on tractor
What would case a lely tractor mower vibrating?
Some thing is loose do insection by hand check blade an nut if it has one look real good
Jul 08, 2014 | Garden
Weed eater one friction disc problem
HOW REPEAR THE FICTION HOB WEED EATER TRACTORS
Aug 22, 2012 | Garden
How do you replace the belt on the mower
Without looking in the manual, I would suggest removing one of the blade housings. First, jack up the tractor from the middle of the rear axle. Use some jackstands as a safety net to keep the tractor from falling, I usually use two jack stands for total support and be sure to scotch the front wheels so that the tractor is sturdy, unable to move and safe. Next, note the routing position of the belt. I have replaced 2 of these blade housings already from shearing them while mowing. There should be 4 bolts running from the top of the deck thru the blade housing. When this housing is removed take the old belt off and reinstall new belt. Reinstall the blade housing and you should be set.
Jul 15, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Snapper riding lawn mower loosses the power to move up hill from a dead stop even though the motor has plenty of power, how can i fix this? is their a belt that is slipping?
if it is belt driven yes it sounds like its slipping may be worn or some idler pullys are adjustable via a slot in bracket where bolt goes through pully if it is disc driven the rubber disc is probably worn. if mower is a rear engine rider close vent on gas cap,set brake then lift mower from front and stand up on rear bars at bottom by floor you will see a rubber disc which is held on by 4 nuts. if has electric start try not to leave up for too long,should only take 15 min to replace hope this helps
Aug 07, 2010 | Garden
Snapper mower will only pull some in first gear not the other gears
If its like my ol snapper it has a disc drive. The drive disc sets vertical to the horizoltal axel disc or at a right angle. First gear starts out near the center, and as u shift the drive disc moves out creating the higher speeds. The drive disc has a hard rubber rim on the outside edge that runs against the axel disc. When this gets worn down, u don't go.
U need a new drive disc.
ballping
Jul 06, 2010 | Garden
How do you adjust brakes on a 30 inch murray,model 30550A lawn tractor.
Sit on mower find the right rear wheel,put your mowers deck in the lowest position.
look under the mower between the rear of the deck and right rear wheel you will see the transmission and a small disc (looks like a small brake rotor) there is a nut on the outside of that disc and or close to that disc 9/16 or 1/2 inch standard wrench size,turning that nut clockwise tightens the brakes ccw loosens.
May 09, 2010 | Garden
LGT 2654 Husqvarna bottoms out on cut selection 5, how do I fix?? Have tried both rear linkages with 3/4 wrench all the way out, did not improve.
Gage wheels not set properly?
On most mowers, the gage wheels should be just a bit off the ground when sitting on a level surface. Most owners manual give a suggested setting for these wheels.
Oct 12, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
The friction disc get chewed up after about 4 mows, why would this happen?
hard to answer without more info ? what type of mower etc, if its the one i think your asking about a snapper rear engine rider it can eat up a disc because of engine mounting or mis ajustment ? take it to a snapper dealer for this well worth it
Aug 25, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
