Question about Cameras
Picture of camera looks like being shook with explanation mark?
  • 3,506 Answers
It is a shock advisement/warning. Was the camera dropped or banged into somenthing?
Posted on Dec 11, 2014
Will not take a picture with flash
this URL is for the manual for your camera http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/finepix_av100_manual_01.pdf Page 28 explains how to toggle the flash on and off in different modes. It is easy and the explanation is short and clear. It is preferable to use a flash for fill light almost all the time so these modes are really great. However if you are in a low light setting you don't want the flash or you will get the 'snapshot' flash look. Try holding camera very steady and keeping the subject from moving too much and shoot without the flash. Once you get the hang of turning the flash on and off you won't hardly even need to look to do it....
Jan 06, 2014 | FUJIFILM FinePix AV100 Digital Camera
Battery fails to charge, get red exclamation mark even with a new battery
There should be a explanation for the Exclamation Mark in the trouble-shooting section of your cameras manual, did you check that??
Nov 13, 2013 | Fujifilm Finepix Jx550
How to look at pictures after taking them on a Olympus Camedia Digital Camera D-435
Press the Playback button on the back of the camera (marked with a right-pointing triangle). Use the cursor pad to move from picture to picture: left goes back one picture, right goes forward one picture, up and down go back and forward ten pictures.
Jun 24, 2011 | Olympus Cameras
I have a Fujifilm finepix S1600 camera and it has a yello camera symbol with an exclamation mark infront. I cant find out what it means, any thoughts?
The yellow icon is a warning that a slow shutter speed has been selected and to use a flash or tripod for the picture otherwise it could be blurry. An explanation can be found on page 27 and 28 of you user manual. A similar icon but in red and the letters AF will be seen if the camera has failed to auto focus.
Dec 26, 2010 | FUJIFILM FinePix S1600 Digital Camera
Where to look if camera is on good,better or best
If I understand this correctly you wish to adjust the picture quality.
Under menu, Camera Settings, Picture Quality (marked as stars).
If I have misunderstood; please refrase and re-submit your question.
TXS
Jan 05, 2010 | Kodak EasyShare C875 Digital Camera
Pictures look as though they have blinds across them
The CCD (image sensor) is either defective or damaged. This is usually a problem with cameras that are about 3 or more years old. I don't know what make/model camera you have but this issue is well documented. Here's a link to some of the explanations http://www.imaging-resource.com/badccds.html
Mar 16, 2009 | General Electric A730 Digital Camera
Same problem
If the lens does not extend then it is possible that it has become jammed. Sometimes this can cause the camera to sense an error and shut itself down immediately after powering on.There are other explanations for the behavior, but if the lens does not move this is the most likely cause. If the lens does extend but then the camera shuts right back off it is possible that an inner component such as the focusing element is not functioning properly.
IF you are not getting a display on your LCD then it is a CCD sensor issue.There are no home remedies for this problem and you will have to get it repaired.
Jul 27, 2008 | Olympus FE-110 Digital Camera
Horizontal Lines
the problem is on the obturator, is blocked, doesn´t close when u give a shot, u can see if u look to the lens and take a picture at same time, if see one that is working properly u will see that the obturator closes and open as u take a picture. probably u will need to send her to the dealer
Jan 18, 2007 | Canon PowerShot A70 Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 20 in the D-425 Advanced Manual in Section 2, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation. This Advanced Manual is provided on a separate CD, in Adobe PDF format.)
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Cameras Logo
22 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
