Question about Vitamix 5000 Work Top Blender
Is it possible to get the wired diagram for vitamix 5000
Where do some of the wires go off the motor and the controls
  • Vitamix Master
  • 1,631 Answers
Try the folks at VitaMix...
Contact Us Customer Service Vitamix
They may be of great service to you??
Posted on Mar 16, 2015
  • Vitamix Master
  • 1,316 Answers
Can't find a wiring diagram but I do have a 34mb video showing a motor being replaced. If you want a copy email me at screaming_skull@hotmail.com I haven't searched You Tube, you may find something there.
Posted on Dec 11, 2014
3 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: need vitamix super 5000 manual in order to use the
Hello, lawrence
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
johnpmccalle
SOURCE: 8 yr old vitamix 5000
I am having a similar issue. Vitamix Corp with rebuild your machine for $145, shipping not included. Call their service center for details. Did you try the machine again after it cooled. Maybe it was the high temp limit switch. Best of luck.
Posted on Jun 07, 2012
Vitamix 5000 variable speed control broken
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
May 18, 2015 | Vitamix 5000 Work Top Blender
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Mar 31, 2015 | Vitamix 5000 Work Top Blender
Vitamixer repair, tulsa, ok
Give them a call and ask for a local service agent.
To speak to someone about having your Vitamix product serviced, please call 800.848.2649.
Sep 13, 2014 | Vitamix 5000 Work Top Blender
I have a vitamix VM0109 and the spindle that the drive socket attaches to has sheered off, is it possible to replace it, if so where can i get the part from, whats the part number and where can i find...
Drive socket meaning the clutch drive on top of the motor? If the shaft that part fits onto has sheared off then prepare to empty your wallet because that is the motor.
Oct 23, 2013 | Vitamix 5000 Work Top Blender
I have a vitamix VM0109 and the part that the
check my viideo on vitamix sprocket repare https://youtu.be/Dq-kDO6H6N4?list=PLHtEamyrXElkiax86_fZYWR5UmgmevL2_
Can't unscrew drive socket on vitamix super 5000 to replace it. The 5/64 hex wrench does not fit in. And another problem is that variable speed does not function. It is possible only slow or high speed.
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop. Speed control problem will likely involve replacing the control switch assembly.
Aug 25, 2013 | Vitamix 5000 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Manual for Vitamix 5000
Manual-Cookbook -Getting Started $0.99 1 bid. Buying Info 4d 21h 52m ...
shopping.superpages.com/vitamix+5000~BEFID_96301 - 60k - Cached
Jan 22, 2009 | Vitamix 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
197 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
