Question about Sharp Office Equipment & Supplies
Sharp UX-460 paper jam message, does not feed or clear" Cleaned rollers with alcohol; looked at manual - no other advice ther
Question is more or less answered in replies relevant to other machines. Sensor is blocked somehow. thanks. bt
  • 3,506 Answers
Try www.manualslib.com
or maybe
pdf.textfiles.com/.../Sharp%20UX-460%20Plain%20Paper%20Fax%20w
Posted on Dec 11, 2014
  • 12 Answers
SOURCE: Fax Machine Jams Everytime I Try to Load Paper...
Is it jamming at the document feeder, or in the blank paper tray? You may need to clean the feed rollers. Use a lint-free cloth (not paper) and some alcohol.
Posted on Jan 27, 2007
SOURCE: Cannot find solution to how to replace paper for the Sharp UX-108 Fax machine
This manual covers several models including the UX-108 and has a diagram for paper loading.
http://www.feedroller.com/Store/Service%20Manual/UX178C_1.PDF
Posted on Jan 23, 2008
SOURCE: sharp fax machine
Please help. Can Sharp UX-BD90 tel/fax machine be set to mute incoming calls?
Thankyou.
Posted on Jan 29, 2008
SOURCE: Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
Posted on Mar 05, 2009
Guru Guy
  • 95 Answers
SOURCE: My Sharp UX-A255 won't let me fax anything. It
Is it receiving faxes? Make sure you have the line in the right place in the back of the machine (line) and that you get dial tone (hit the monitor button if it has one). Try calling it on your cell to see if it picks up. You may have a poor phone line conditon, and you could try to slow the modem speed down or check the ECM (Error Correction Mode) if so. If it's a jamming problem, try to run a copy and see if it feeds ok. If not try cleaning the feed/pick up rollers with mild soap and water. Reseat the paper and try it again.
Posted on Oct 27, 2009
Testimonial: "I checked all the connections. There was a dial tone and I am able to receive faxes. I loaded the paper again and all of the sudden it went through. "
It does not pick the paper & orange light on in triangle. they have not paper jam
clear paper feed roller by using wet cloth or alcohol!
1. Open paper tray
2. look for paper feed roller just in bottom of printer
3. clear it as i said early
4. Enjoy
Good Luck!
Jan 19, 2011 | HP LaserJet 2200dn Printer
My Sharp UX-A255 won't let me fax anything. It starts up and then comes up with the message Line error or paper jam. There is nothing jammed.
Oct 27, 2009 | Sharp UX A255 Plain Paper Thermal transfer...
Sencor problem
Pull the paper tray out and look inside.You'll see the feed roller.It needs to be cleaned with alcohol or water.Usually,paper dust on the roller causing it to loose friction and it starts slipping during paper feed,and printer jams.
Oct 08, 2009 | Samsung CLP 300 Laser Printer
Hp 4250 tn when i try to print get an error 13.05.00 papper never makes it though the fuser
Error message means "Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken."
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Try cleaning your feed rollers...
There are two types of rollers in printers: hard plastic and rubber. Plastic rollers can be cleaned with alcohol (isopropyl). Rubber rollers can be cleaned with a rubber roller cleaner and restorer like the one in the link (you can find other brands, but make sure its for rubber).
http://www.lmcomp.com/80008.html
Jul 27, 2009 | HP LaserJet 4250n Printer
Sharp fax - drum won't grab paper in order to send fax
Open the top and clean the rubber rollers with alcohol. Wife them well with a lint free cloth. Parae towels will put more junk on them.
Mar 08, 2009 | Sharp UX-B750 Inkjet Fax
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Dec 27, 2006 | Sharp UX-B20 Plain Paper Inkjet Fax
78 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
