Question about Music
I bought a GNX3 from pawn shop, but it doesn't seem to register any input signal coming in to the unit
Made sure my guitar/cords are good. they are sending signal. tried to plug in CD player into CD in/jam along jack.. no signal seems to be getting in. even on the tuning setting.. it says its ready for me to tune the guitar but i hit a string and nothing registers on the machine
  • Music Master
  • 3,506 Answers
You will have to have the system checked out and as it came from a pawn shop it likely is not functional as it is/was
Posted on Dec 11, 2014
  • 6 Answers
SOURCE: Guitar strings on a mandolin.
By now you may have solved this problem, but maybe this information is still helpful:
What you are essentially recreating is a tenor guitar. Many companies make tenor guitar strings. I would suggest D'Addario J66 80/20 Bronze Tenor Guitar Strings (10-32). I've done this a few times and it is quite fun and makes for an interesting travel guitar.
Have a blast!
Posted on Jan 09, 2009
  • 17 Answers
SOURCE: "G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Posted on Feb 03, 2009
SOURCE: LP epiphone 100 "g" string problem,
well, i have this guitar, for me if i bent the string it would pop off the nut, but it went out of tune on me also becuase of the tuners. so i suggest checking the nut to make sure the string sits completely flush in there, and than also just upgrading your tuners if you can and it will be fine. but deffinately upgrading your tuners would stop that hopefully but still could be something with the nut becuase i had both. tuners = machine heads
Posted on Mar 25, 2009
  • 5603 Answers
SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Posted on Sep 22, 2009
  • 5603 Answers
SOURCE: I just got this guitar. I pull the tuner control,
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Posted on Feb 06, 2010
Digitech gnx3 makes cracking noise and the clip indicator comes on when it does
Hi Chris,
This is a discontinued product for the work station. Digitech does have a firmware update on their website. Have you tried that? Other then that, usually a bad guitar cord, dirty input jack or faulty input jack caused the cracking sound. These units sit on the floor where dirt and dust collect. Try spraying the input jack with a good quality conduct cleaner. (Radio Shack?) Make sure your guitar jack is also clean and then "exercise" the input by plugging the cord in and out several times. I am assuming this may help since it is the most simple approach. Otherwise, it may be a component issue and that cannot be addressed via email.
Mar 02, 2017 | The Music
The unit is likley defective and you will need someone to diagnose and fix it, someone who does electronics repair and diagnosis
Dec 10, 2014 | Music
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall mg100hdfx head. I get no sound whatsoever plugged into the guitar input but the controls seem to work as I can hear changes in the light ambient static. I will get sound however if I plug directly...
You MAY have a broken input jack. If you can hear changes from the overdrive gain control, that control is just one stage away from the input jack. Also there is a capacitor C60 that is for RF bypassing and if that shorts that will kill the audio. Yes, inout jacks get destroyed by tripping over guitar cables... that is why you run the cord through the amp handle before plugging it in. Of course verify your guitar and cable is good using another amp.
Aug 30, 2011 | Music
When I plug in my guitar to the Fender Frontman 64R Amp and I just barely move the cord, it make this really loud screeching type noise. It's not an old amp; I got it about five months ago. I can't...
Yes, there are several possibilities. First thing is to disconnect your guitar and then plug in the cord to the amp. Expect a bit of hum. If it screeches, then problem is not feedback via the guitar. If it doesn't MAYBE your guitar is "hearing the amp" which the guitar is then a microphone and can feedback. Moving the cable generates electrical noise which can trigger the feedback to start.
If you get the screech without the guitar connected, then TRY a new guitar cable. Make sure it is an INSTRUMENT cable... I have seen some try to use speaker cables or junky 1/4 inch cables intended for home stereo... these will NOT work and can cause the feedback. The next possibility is a broken jack on the amp. This would require repair. The common cause of this is to fail to run the cord through the handle of the amp... one trip on the cord or step on it pulling the plug sideways in the amp and the jack is broken and it is a trip to the shop as well. While on the subject ALWAYS run the cord at the guitar end either through the strap or your belt loop. Cords left dangling keep rotating and soon wear out the plug and also the jack in the guitar and then that has to go to the shop.
May 16, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Hi, I have an RBX 374 and I cannot get any sound from it. I have got the wiring scheme but the wiring looks O.K. Some say it might be the pre-amp. Does anyone know what could be the problem...
i dont' see where this model has active pickups (guessing this is what you mean by pre-ampped).
The issue can be in a few places.
1) the strings could be too far from the pickups and the instrument needs to be tuned.
2) the pickups are bad
3) your jack is bad
4) the cable is bad
5) your equilizers are not corrected
6) your volume control is turned down or damaged
7) your amp is damaged
this is a small list of the basic possibilities.
Mar 29, 2011 | Yamaha Rbx374 4String Electric Bass Guitar
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
How do i plug my eletric guitar into an amp
Connect a 1/4" instrument cable from the guitar's 1/4" jack to the amp's 1/4" input.
Oct 02, 2009 | Dean Guitars Dean Ml79 Electric Guitar
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
