Question about Kitchen Ranges
<!-- from fixya rte -->F11 error code on frigidair range - Kitchen Ranges
  • 932 Answers
Rose,
Check this link for possible help and directions. Newer Frigidaire Range Fault Codes
Posted on Dec 12, 2014
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
fixyourboard
  • 310 Answers
SOURCE: f11 err
You must be Canadian?
F11 means that the controller thinks there is a stuck key on the keypad, which may or may not be the cause.
You might try pushing each button several times, then the clear button to see if you can unstick it.
Sometimes this is caused by a failure in the oven controller itself (but more often the keypad).
We repair oven controllers if it comes down to that.
Happy Canadian Thanksgiving!
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
Testimonial: "Thanks - guess I'll stay near my oven until I get it fixed. Perhaps the cleaning ladies went at it too hard yesterday!"
blueextc3221
  • 15935 Answers
SOURCE: Hi,Im tech and I have a problem with range
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%TG
Posted on Oct 01, 2010
  • 1116 Answers
SOURCE: Our Frigidaire Range..the Oven Lock
If the error is persistent, than the chances are your EOC Control Assembly is failing and needs to be replaced. Depending on your exact model number, the price should be about $280.00. I will tell you that this is a common issue and some of our customers report calling Frigidaire and complaining to the point they are sent the part for free. You can reached them at 1 (800) 374-4432.
Posted on Aug 09, 2011
  • 17 Answers
SOURCE: Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
Posted on Dec 13, 2012
How do I fix beeping F11 error code on my frigidaire stove?
The F11 error code stands is a shorted keypad. I suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least 5 minutes. If that does not work you may need to have a professional technician
Sep 28, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
After a power outage, what is causing my Frigidaire stove to beep and display an F11 code?
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
Apr 23, 2015 | Frigidaire Kitchen Ranges
Is the F11 error code usually caused by the over control board or the overlay
Thank you for your inquiry, Warren!
From my understanding you are receiving an error code of "F11" on your Frigidaire range. Typically an "F11" code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by disconnecting power from your range for roughly ten minutes. If that does not help correct your issue you may need to replace the EOC (Electronic Oven Control). This is not a simple DIY job and I would recommend having a professional technician out to assist you with replacing the electronic component. Hopefully this is helpful. -Matt
Mar 10, 2015 | Frigidaire Kitchen Ranges
Frigidaire model number FEFL79DSB showing a F11 code on the control panel. Oven will not turn on and I am getting a alarm.
I appreciate your post, Dale Miller!
From what you have described your Frigidaire range is displaying an error code of "F11" and you are receiving an alarm. Normally an "F11" error code stands for a shorted keypad. I would suggest performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" error code you may need to replace your control panel. I would recommend having a professional do so, they will be able to properly disassemble your range and accurately replace the electrical component to not damage anything internally on your range. I hope this information is helpful to some degree. -Matt
Feb 28, 2015 | Frigidaire Kitchen Ranges
The electric stove I have is beeping f11 how do I stop it from beeping
I appreciate your inquiry, friend!
I see that you are having a difficult time with your Frigidaire range displaying an "F11" error code. That error code stands for a shorted keypad and I would recommend performing a reset on your range. You can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" code you may need to replace the EOC (Electronic Control Panel) this is not a simple DIY job. I would recommend contacting a professional technician for proper disassembly and repairs to be completed. I hope this is helpful information. -Matt
Feb 25, 2015 | Frigidaire Kitchen Ranges
F11 error code
I appreciate the post, dan moore!
From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
Dec 14, 2014 | Frigidaire Kitchen Ranges
F11 error code
Thank you for your post, Friend.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
Aug 13, 2014 | Frigidaire FGB24S5A Gas Single Oven
F11 ault code. what does that mean?
Hello Polly, this is Z. I am happy to assist you!
Mar 19, 2014 | Frigidaire Kitchen Ranges
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
