Question about Panasonic KX TGA641 Cordless Phone
Proceduar for tuning new hand set to base station
  • 32 Answers
The answer is on page four of this manual:
http://service.us.panasonic.com/OPERMANPDF/KXTGA641.PDF
Posted on Dec 13, 2014
2 Suggested Answers
SOURCE: No KX-TGA101S communication with KX-TG1033S
The additional handsets must be registered to the base unit. Here are the instructions from the manual:
HANDSET
1. [menu}
2. "handset settings" - OK
3. "Registration" - OK
4 "HS registration" - OK
BASE UNIT
Press and hold [LOCATOR] until the registration tone sounds.
-if all registered handsets start ringing, press {LOCATOR] to stop, then repeat this step.
-after the base unit beeps, the rest of the procedure must be completed within 1 minute and 30 seconds.
HANDSET
Press [OK], then wait until a beep sounds and Y stops flashing.
Posted on May 05, 2009
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
I have a vetch base of cs6619 and have ordered and received a new hand set Cs 6609 and can not get it registered although it has been charging foe 2 days. Please advise.
Sometimes you have to start from scratch. Remove the battery from all the portable units (including the one at the base station). Then start by setting up the base station.
You might try less drastic steps that are similar if you don't want to lose your directories.
Mar 05, 2015 | Vtech DECT 6.0 Digital Cordless Phone
Chrysler 300 radio cannot pre-set tuned stations
If radio has save button then tune your station push save button then push a number on preset you want it saved to. The radio automatticlly stores the strongest station in your area.
Feb 20, 2013 | Chrysler Cars & Trucks
I have just purchased two srp2003/27 remote controls..i cannot enter set up mode because neither one of my tv's has a channel 1....the lowest one goes is 3 and the other 2..what can i do?
All TV sets go as low as channel 1. Its just that your tv has been preset to skip certain channels because no station was stored on them. All you have to do is go to the unit and manually change the stations with the program button.
If on the other hand this does not work try going through the menu button like you want to tune a new station and after tuning a station select it to be saved in position 1 Then you can acces channel 1.
Hope this solution has been helpful?
Sep 23, 2010 | Televison & Video
The base ringer on my Uniden TRU9480 base station rings very loud and cannot find where to either adjust or discontinue the ringer. Jackgee1
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
May 01, 2009 | Uniden 2.4 GHz Cordless Phone System
Plantronics CS60
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Aug 20, 2008 | Plantronics CS60 Professional Headset
Initializing
The hand-sets are not registered with the base-station. Reset system by: remove batteries, unplug base station, disconnect batteries in all hand sets. Wait 15 minutes. Reinstall batteries in hand sets. Reinstall batteries in base station, plug base station in. Place each hand set in the base station until it automatically registers (usually immediately, or within 1 minute or so).
If that doesn't fix the problem, if possible, return the system to where you bought it for exchange or refund. If that isn't an option, call Thompson help line. They are not particularly knowledgeable, but will authorize a return to the a repair center. The process is slow...
My experience: The two hand sets that came with my system worked perfectly, but none of the three additional handsets I purchased would register. The three additional handsets I purchased were the last three on the my retailer's shelf, so, retail exchange wasn't an option. I contacted Thompson and they authorized return for repair or replacement. The repair center received my handsets on October 29, 2008. Its now November 27, 2008 and I'm still waiting.
Mar 03, 2008 | GE 28128EE2 Phone
Ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Jan 14, 2008 | GE 25932 Twin Cordless Phone
Phillips phone cd445
On the hand set:
- menu button - ADVANCED SET - REGISTRATION - base 1
- pin # is 0000 (default)
On the base station and the base station handset - press and hold for at least (3) seconds, at the same time:
- on base - the intercom button
- on base handset - menu button
It's in the manual but you need a magnifying glass to read it.
Dec 30, 2007 | Lands Phones
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
Panasonic KX TGA641 Cordless Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
