Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I am trying to establish if there is a standby power problem.
Yes it has a stand by light and it is red . once the power on is started it checks the rest of the command lines from micro and starts the initialization process once all are satisfied it un mutes the picture
. however it appears your fighting a one problem and possibly compounding the problems now .
Posted on Dec 11, 2014
SOURCE: RCA MODEL#D52W20 WHEN TURN ON
Two major problems occur to cause this, and both are on deflection p.c.b. First, after removing the back look for two or three capacitors in the power supply that are bulging or have exploded in power supply and replace. You can see this looking down on chassis and this occurs on the top of the components in question. Second, look for burn marks or arcing around high voltage transformer, or simply a shorted horizontal output transistor. You will need an ohm meter to test the transistor. These solutions have fixed every identical set to yours,(20 or so) If you would rather replace the board try PTS out of bloomington or google your model number for replacement parts. Good luck.
Posted on Jun 09, 2008
SOURCE: D52W20 red convergence problem
Do you see in Menu go to setup look for convergence if it is not there you have a open fuse 400ma FL231. Try This place for Parts http://servicemanuals.vstore.ca Let me know if you need anymore help.
Posted on Dec 31, 2008
SOURCE: I have a RCA model# D52W20. The TV will not power up.
ON the deflection board ck capacitors 114,130,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and the other 2 are 220uf 35v replace all 3 of them and resolder around all pinns on FBT flyback transfomer.
Posted on Apr 09, 2009
SOURCE: RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Posted on Jun 05, 2009
Jan 15, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dec 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Oct 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Aug 28, 2009 | RCA HD52W58 52" TV
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Oct 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Apr 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
