Question about Simplicity Vacuums
The brush has stopped turning my simplicity vacuum. what do I do
Nothing
    Genius:
  • 2,494 Answers
Turn it upside down and check the brush is not jammed or the belt broken.
Posted on Dec 11, 2014
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
  • 120 Answers
SOURCE: stopped running
orecks have a plastic fan inside and everything you pick up hits it, sometimes things can get stuck in there or break the fan locking up the motor. With the machine off, poke around where the dirt goes into the motor, behind the roller and see if you can pull anything out.
Posted on Jan 12, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
SOURCE: Simplicity 7 Series Vacuum. Suddenly stopped.
There is a thermal reset button on your vaccum. It is on the rear of the unit, just below the attachments and next to the sticker with the serial numer etc on it. The vacuum is designed to turn itself of if too much heat gets built up to prevent it from "burning up."
Posted on Dec 29, 2009
VacuumRepair
  • 438 Answers
SOURCE: brush roll belt stops turning when in position to
I think I know what the problem is with your machine. It's a rather lengthy repair, and I'll be happy to photograph it for you (like I do on most of my Fixya answers), but I'd like to know before doing all of that if you still need help, or if you've already fixed it.
Thanks,
CJ
Posted on Apr 10, 2010
How do I Pull apart a Simplicity Synchrony?
The noise is likely the brush roll or the lower motor fan if you only hear it when you turn on the brush roll. Remove the bottom plate to examine the brush roll, there are screws on the bottom of the vacuum that must be removed so that the top nozzle housing cover can be removed. Remove the screws to take the cover off the nozzle housing from the brushroll to the lower motor so you will be able to inspect the fan in the lower motor. You have a high quality precision vacuum that is not easy to repair without proper training. It may save money and provide better results to have it repaired by a qualified Simplicity or Riccar repair shop.
Jan 23, 2017 | Simplicity Vacuums
Why can't I get brush roller to stop hitting the surrounding bale?
The brush roller may not be in its normal seated position.
Feb 21, 2016 | Simplicity Vacuums
Simplicity freedom vacuum will not self propell ?
there is a seperate belt.one that turns the brush,one for propell..
Dec 13, 2015 | Simplicity Vacuums
HOW TO CANGE BELT ON SIMPLICITY 9.8 VACUUM
This is pretty easy. Turn vac upside down, remove brush cover, brush with belt on it pops out on each side. You must get the exact replacement belt so take your model number and any other numbers to vacuum repair shop. The belt around brush then around motor spindle, replace brush and cover.
Jun 20, 2014 | Simplicity Vacuums
My simplicity 7200 does not have vacuum. Air comes out the front post filter area
If air is coming out of the filter air has to be going in through the suction hose but it may be restricted with a clog. Replace the bag and both filters. If it's been over six months since the belt has been changed start by changing the belt. Most of the vacuums brought to my store with the customer stating "it has no suction" actually have great suction but no agitation from the brush roll. If the belt is not turning the brush roll fast enough when vacuuming the carpets it will not even pickup lint and hair.
Oct 28, 2013 | Simplicity 7850 Premier Bagged Canister...
Where is the clutch assembly on simplicity 7350 upright vacumn
The clutch is part of the brush roll. Remove the bottom plate to see the brush roll and clutch. The rod that attaches to the brush roll activates the clutch
Nov 18, 2012 | Riccar 8900 Simplicity 7822, 7300, 7350,...
Simplicity F3500-- how do I get the bottom off to change the belt?
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is http://www.simplicityvac.com/about-my-simplicity/manuals/FreedomManual_Update0803.pdf . Most Simplicity vacuum manuals are available at their support site: http://www.simplicityvac.com/about-my-simplicity/manuals/ .
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
I started my Simplicity 4800 vacuum and it sparked, turned off and smells like smoke. What do I do, please?
Sounds like carbon brushes or bad motor.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
May 14, 2011 | Simplicity Vacuums
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Vacuums Logo
154 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
