Question about Amana Heating & Cooling
I have removed front cover on amana model ptc153b35am unit says it has got a manaul reset for heater cannot locate it can you help
Turn heater on blows only air no heat
    New Friend:
    Problem Solver:
  • 6 Answers
The manual reset is a small switch on the computer control board. If that doesn't fix the problem, while you are there, you will see 2 small black boxes wired into the computer board marked "heater 1" and "heater 2". These are relays, one of which has probably gone bad. You can either order a computer board for about $100 or replace the relays yourself with a soldering gun. You can order the relays for $4.02 apiece from Digi-key Corp. Part # is JTN1aS-PA-F-DC5V for the relay.
Posted on Dec 14, 2014
SOURCE: Amana ac/heating unit model PGD60C1152E
It sounds like your blower is coming on before your heat. With gas if your unit is new enough, typically you have an ignition mode to start your heat process, flame recognition, and then full burners, heating up your heat exchanger, and then bringing on your blower. Your blower maybe controlled by a circuit board, just depends upon age of your system.
Posted on Nov 20, 2007
ACTECH
  • 80 Answers
SOURCE: unit blows cold air instead of warm (burrrr)
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Posted on Dec 01, 2007
  • 86 Answers
SOURCE: no heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Posted on Mar 16, 2008
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
  • 659 Answers
SOURCE: Amana air and heating unit model # ptc153b50am w/ power cor 37470
Sounds as though the power cord reset switch might be bad and need to be replaced. If not, then there is a short somewhere in the system. Do an ohms test on the switch to determine if it is bad.
Posted on Mar 17, 2009
I need a repair person in Ft. Myers, FL for this product.
You will have to go online through the yellow pages app and you will find someone whose a professional on a/c and they will be able to assist you.
Jul 10, 2015 | Amana Heating & Cooling
Where is manaul reset
Hi
If mid wall split, open the evaporator and on the left side there is either a cover with one screw that you open and a black reset button will be there
Dec 10, 2014 | Amana Heating & Cooling
O they make a radiator type cover that works for this unit?
Improve the FixYa experience for everyone by voting.
If you are interested, Just Cover It Up has just come to my attention and they have the widest selection around. Their claim to fame is:
Air Conditioner Covers for Central, Window, and Wall Units.
CLICK HERE
I have no personal interest or association with any product that I may suggest.
May 19, 2012 | Amana DigiSmart PTC153B35AM...
Work in a hotel and I have some broken front covers and was wondering if you sell them (just the plastic front covers) and any phone or email to get in touch and compraselas
Sir, we don't and can't sell anything on this website, other than information on how to repair something or where YOU can find it. In this case, I would suggest that you contact the manufacturer, Amana directly.
Apr 07, 2011 | Amana DigiSmart PTC153B35AM...
I have an Amana PTAC unit model no. PTH153B50AM. It will not heat, but the fan runs continuously in the heat mode. The unit has a label that says it has a manual reset for the heater, but no direction as...
First unplug the unit......Take the front cover off, take the wire screen off where the front fan is there is 4 or 5 screws that hold the plate that was under the screen. The electric heating elements are under that plate between the evaporator coil and the front blower wheel. It will lift straight up and give you access to the elements. In the electric heating element area there is a limit switch with a red or black button in the center of it push it to reset the limit it is on the right hand side by the controls. I wish I could find a picture to show you but I couldn't find one. It is not easy to get to... Hope this helps.
Feb 12, 2011 | Amana PTH153B50AM Air Conditioner
Heater stopped working. Fan works, control panel diagnostic check reports no failure code. Placard on front of unit says heater unit has manual reset, I can't find a reset button or breaker for heater....
The front panel should be held in place by four screw at the corners or snap in place. Either remove screws or pull gently on top right corner to remove cover. You should see a red reset buttom type reset. Push it in to reset. Hope this helps. Thanks.
Nov 13, 2010 | Amana PTC123D50AR Air Conditioner
I have a AMANA PTh153B50AE (PTAC unit). The air conditioner works fine. It is when I turn on my heater and it does not get warm. It just blows cold air. I have looked at the board and it appears that...
I have the same problem, and I found the manual reset inside the unit. Turn the power off, and unplug the unit. Remove the outer cover of the unit ( inside cover ) , and remove the 2 screws holding the " wire mesh " in the front of the cover. Pull the wire mesh up and out of the way, then carefully pull out the heating element.
On the heating element, where the wires are connected, there is a manual reset button... Push the button in, till it resets...
My reset was on the upper left connection of the wires... just looks like a small push button, but the reset is recessed a bit.
Replace all covers and plug back in.. working fine..
Nov 12, 2010 | Amana PTH153B50AE Air Conditioner
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
I have an amana model no. sqd26vw and would like to know where i can find the defrost timer. thanks, jim
It is on the back left corner of the frame. Remove the dust cover to locate the timer.
Jun 14, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Unit blows cold air instead of warm (burrrr)
Nov 23, 2007 | Amana PTC153B50AJ Electric Heat Air...
Heating & Cooling Logo
151 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
